coq-club - Re: [Coq-Club] Co-induction with existential quantification?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Co-induction with existential quantification?
  • Date: Sun, 11 Jan 2015 09:01:26 +0800
Yes, this solves my problem!  Thanks very much!
Hongjin
On Sat, Jan 10, 2015 at 5:16 PM, Xavier Leroy <Xavier.Leroy AT inria.fr> wrote:
On 10/01/15 05:04, Hongjin Liang wrote:
> Require Import Relations.
> Variable Node : Type.
> Variable edge : relation Node.
> CoInductive InfPath : Node -> Prop :=
>   | infpath : forall x y,
>                edge x y ->
>                InfPath y ->
>                InfPath x.
> CoInductive Trace : Type :=
>   | cons : Node -> Trace -> Trace.
> CoInductive InfPathWithTrace : Node -> Trace -> Prop :=
>   | infpathtr : forall x y T,
>                 edge x y ->
>                 InfPathWithTrace y T ->
>                 InfPathWithTrace x (cons x T).
> Lemma infPath_existTrace :
>   forall x, InfPath x -> exists T, InfPathWithTrace x T.
> Perhaps this lemma is actually incorrect?  Any idea or suggestion is greatly
> appreciated.
As a general guideline,
induction lets you prove statements of the shape
          inductive-hypothesis -> ...
and coinduction lets you prove statements of the shape
          ... -> coinductive-conclusion
Your lemma has shape
          coinductive-hypothesis -> inductive-conclusion
so neither induction nor coinduction will help.
The trick is to explicitly construct (with a CoFixpoint) the trace T
such that InfPathWithTrace x T holds:
CoFixpoint TraceofInfPath (x: Node) (ip: InfPath x) : Trace := ...
Lemma infPath_trace:
  forall x (ip: InfPath x), InfPathWithTrace x (TraceofInfPath x ip).
Proof ... Qed.
Proof.
  intros x ip. exists (TraceofInfPath x ip). apply infPath_trace.
Qed.
The construction of the trace is not obvious because InfPath is in
Prop while Trace is in Type.
Solution #1: put InfPath in Type.
CoInductive InfPath : Node -> Type :=
               edge x y ->
               InfPath y ->
               InfPath x.
  match ip with
  | infpath x y edge inf => cons x (TraceofInfPath y inf)
  end.
Solution #2: use classical logic, e.g. an axiom of description.
Require Import ClassicalEpsilon.
Definition invertInfPath (x: Node) (ip: InfPath x)
                       : { y | edge x y /\ InfPath y }.
Proof.
  apply constructive_indefinite_description.
  inversion ip; subst. exists y; auto.
Qed.
  match invertInfPath x ip with
  | exist y (conj edg inf) => cons x (TraceofInfPath y inf)
  end.
Hope this helps,
- Xavier Leroy
