coq-club - [Coq-Club] How to avoid repetition in proving basic facts?
  • From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: [Coq-Club] How to avoid repetition in proving basic facts?
  • Date: Mon, 19 Jan 2015 14:48:42 +0000
  • Accept-language: de-DE, en-US
Dear Coq Users,
I found that the module system and also the type class system are very
effective for building up higher structures from basic structures, but I find
it difficult to avoid repetition in defining the basic structures. E.g. I use
identical scripts to define the ssreflect equality, countable, choice and
finite structure for a few basic types, but I couldn't manage to put this
into a module or other Coq structure which avoids copying the same script a
few times.
The reason I ask is that I am working on some framework where the "higher
structures" are given be the framework and the user is mostly providing basic
structures and their connection, and I want to give some comfort for this.
With modules my problem is that a module evaluates the proof scripts when the
module is defined, not when it is instantiated. This means that all
properties of a type which are required for the proofs must be defined in the
module type parameters. I think for properties as basic as being a finite
type, it is hardly possible to collect properties in a module type which
allow to proof this without giving a proof for finiteness itself. So I wonder
if there is a way to have modules, which evaluate proof scripts when the
module is instantiated with a specific type. In the end I want to be able to
instantiate a module with an arbitrary type and see if the proof scripts run
through. I want this only for some basic types. For the higher order work the
module and type class system are fine as they are.
Another thing I could imagine to work is a Tactic Notation, which works at
the level of "Definition" "Canonical Structure" and so on.
Is there a mechanism in Coq which could solve this?
Thanks & best regards,
Michael
  • [Coq-Club] How to avoid repetition in proving basic facts?, Soegtrop, Michael, 01/19/2015
