- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Simplification of terms generated with tactics
- Date: Mon, 19 Jan 2015 10:39:28 -0500
On 01/19/2015 06:06 AM, Soegtrop, Michael wrote:
Dear Coq Users,
using Jonathan Leivant's ideas on the split tactic, I created a tactic which produces for simple
enumeration style inductive types a list of all values (see attached Coq script). It works fine,
just the returned "proof term" contains some unnecessary overhead (a function
definition which is never used). I wonder if there is a way to modify the tactic such that the
resulting "proof term" is just the list, without the overhead.
I don't think this is possible in 8.4, as you can't simplify a proof term built tactically while being "inside" of it, and there does not seem to be any way short of defining a function in proof mode to get an external handle on something built tactically. In 8.5, it is easily done by building the proof term in a $(...)$ construct, then using eval compute on that prior to using it as the body of the function.
It is unfortunate that you can't move easily to 8.5, as it sounds like what you are trying to achieve is done most easily in 8.5. For instance, see my posting on Dec 20, 2014 titled "using $(...)$ and admit to analyze tactic results" - which shows a way in 8.5 to generate a term containing the constructor information for an arbitrary inductive type. I omitted the printed result from that posting, assuming any interested parties would try it in a trunk version for themselves. Here it is:
(forall f : foo 1, f = Foo1 -> True,
forall (f : foo 2) (b : bool), f = Foo2 b -> True,
forall f : foo 3, f = Foo3 -> True,
forall (f : foo 4) (n : nat) (f0 : foo n), f = Foo4 n f0 -> True)
based on analyzing the inductive type:
Inductive foo : nat -> Set :=
| Foo1 : foo 1
| Foo2(b : bool) : foo 2
| Foo3 : foo 3
| Foo4(n : nat)(f : foo n) : foo 4.
-- Jonathan
- [Coq-Club] Simplification of terms generated with tactics, Soegtrop, Michael, 01/19/2015
- Re: [Coq-Club] Simplification of terms generated with tactics, Jonathan Leivent, 01/19/2015
- RE: [Coq-Club] Simplification of terms generated with tactics, Soegtrop, Michael, 01/19/2015
- Re: [Coq-Club] Simplification of terms generated with tactics, Pierre Courtieu, 01/19/2015
- RE: [Coq-Club] Simplification of terms generated with tactics, Soegtrop, Michael, 01/20/2015
- Re: [Coq-Club] Simplification of terms generated with tactics, Pierre Courtieu, 01/20/2015
