- From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] Simplification of terms generated with tactics
- Date: Mon, 19 Jan 2015 15:58:06 +0000
- Accept-language: de-DE, en-US
Dear Jonathan,
It looks like I should give 8.5 a try and see if the other things I need work
out of the box. Are there 8.5 prerelease versions which passed a reasonable
set of regression test or should I just use the git trunk version?
Best regards,
Michael
-----Original Message-----
coq-club-request AT inria.fr
[mailto:coq-club-request AT inria.fr]
On Behalf Of Jonathan Leivent
Sent: Monday, January 19, 2015 4:39 PM
To:
Subject: Re: [Coq-Club] Simplification of terms generated with tactics
On 01/19/2015 06:06 AM, Soegtrop, Michael wrote:
> Dear Coq Users,
> using Jonathan Leivant's ideas on the split tactic, I created a tactic
> which produces for simple enumeration style inductive types a list of all
> values (see attached Coq script). It works fine, just the returned "proof
> term" contains some unnecessary overhead (a function definition which is
> never used). I wonder if there is a way to modify the tactic such that the
> resulting "proof term" is just the list, without the overhead.
I don't think this is possible in 8.4, as you can't simplify a proof term
built tactically while being "inside" of it, and there does not seem to be
any way short of defining a function in proof mode to get an external handle
on something built tactically. In 8.5, it is easily done by building the
proof term in a $(...)$ construct, then using eval compute on that prior to
using it as the body of the function.
It is unfortunate that you can't move easily to 8.5, as it sounds like what
you are trying to achieve is done most easily in 8.5. For instance, see my
posting on Dec 20, 2014 titled "using $(...)$ and admit to analyze tactic
results" - which shows a way in 8.5 to generate a term containing the
constructor information for an arbitrary inductive type.
I omitted the printed result from that posting, assuming any interested
parties would try it in a trunk version for themselves. Here it is:
(forall f : foo 1, f = Foo1 -> True,
forall (f : foo 2) (b : bool), f = Foo2 b -> True, forall f : foo 3, f = Foo3
-> True, forall (f : foo 4) (n : nat) (f0 : foo n), f = Foo4 n f0 -> True)
based on analyzing the inductive type:
Inductive foo : nat -> Set :=
| Foo1 : foo 1
| Foo2(b : bool) : foo 2
| Foo3 : foo 3
| Foo4(n : nat)(f : foo n) : foo 4.
-- Jonathan
- [Coq-Club] Simplification of terms generated with tactics, Soegtrop, Michael, 01/19/2015
- Re: [Coq-Club] Simplification of terms generated with tactics, Jonathan Leivent, 01/19/2015
- RE: [Coq-Club] Simplification of terms generated with tactics, Soegtrop, Michael, 01/19/2015
- Re: [Coq-Club] Simplification of terms generated with tactics, Pierre Courtieu, 01/19/2015
- RE: [Coq-Club] Simplification of terms generated with tactics, Soegtrop, Michael, 01/20/2015
- Re: [Coq-Club] Simplification of terms generated with tactics, Pierre Courtieu, 01/20/2015
