Re: [Coq-Club] (user experience report) "Proof assistants as routine tools", Neil Strickland
- From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] (user experience report) "Proof assistants as routine tools", Neil Strickland
- Date: Sat, 24 Jan 2015 19:06:30 -0500
I'm looking for a constructive proof that runs reasonably fast.
Ideally, the statement should say that given a list of primes, there (constructively) exists a prime not in the list.
By reasonably fast, I mean that it should take only a few seconds to (vm_)compute the answer for small inputs like [2,5,7].
It would great if someone posted complete .v file(s), along with a description of the dependencies.
Thanks,
-- Abhishek
http://www.cs.cornell.edu/~aa755/On Mon, Dec 1, 2014 at 7:17 AM, Enrico Tassi <enrico.tassi AT inria.fr> wrote:
On Sun, Nov 30, 2014 at 01:40:18PM +0200, Ilmārs Cīrulis wrote:
> Probably a bit offtopic.
> It was easy to prove "(exists n, forall p, prime p -> p <=n) -> False".
> But I had a problems proving "(forall n, exists p, prime p /\ p > n".
That is exactly what the proof Cyril and myself pointed to shows.
Lemma prime_above m : {p | m < p & prime p}.
Here we have a sigma-type in Type (denoted with {x | P x}) instead of Prop
(denoted with exists), hence we really construct the witness.
> Do you have any hints? (Also, what does that SSReflect proof do?)
The proof uses some facts from the math comp library, namely
Lemma pdivP n : n > 1 → {p | prime p & p %| n}. (* %| means divides *)
Lemma gtnNdvd n d : 0 < n → n < d → (d %| n) = false.
The theories used are mostly here:
http://ssr.msr-inria.inria.fr/doc/mathcomp-1.5/MathComp.prime.html
http://ssr.msr-inria.inria.fr/doc/mathcomp-1.5/MathComp.div.html
I guess you want to look at the pdiv function, that is the one computing
the witness. Its correctness is not proved directly, but is rather a
consequence of the correctness of the algorithm producing a prime
decomposition (pdiv just picks the smallest item in the decomposition).
Best,
Enrico Tassi
- Re: [Coq-Club] (user experience report) "Proof assistants as routine tools", Neil Strickland, Abhishek Anand, 01/25/2015
- Re: [Coq-Club] (user experience report) "Proof assistants as routine tools", Neil Strickland, Ilmārs Cīrulis, 01/25/2015
- Re: [Coq-Club] (user experience report) "Proof assistants as routine tools", Neil Strickland, Ilmārs Cīrulis, 01/27/2015
- Re: [Coq-Club] (user experience report) "Proof assistants as routine tools", Neil Strickland, Abhishek Anand, 01/27/2015
- Re: [Coq-Club] (user experience report) "Proof assistants as routine tools", Neil Strickland, Ilmārs Cīrulis, 01/30/2015
- Re: [Coq-Club] (user experience report) "Proof assistants as routine tools", Neil Strickland, Abhishek Anand, 01/30/2015
- Re: [Coq-Club] (user experience report) "Proof assistants as routine tools", Neil Strickland, Ilmārs Cīrulis, 01/31/2015
