Re: [Coq-Club] Globally-nameless tactics: Getting rid of the verbose Ltac [match goal with] construct
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Globally-nameless tactics: Getting rid of the verbose Ltac [match goal with] construct
- Date: Sun, 25 Jan 2015 22:03:31 -0500
On 01/25/2015 05:42 PM, Jonathan Leivent wrote:
shape rewrite (f ?[E] = g ?E)
To simplify: wrap the refine and unify work in a "test" tactic so that they are undone even if successful - hence no fear of leaking evars or unintentionally solving them. After all, we only care to know whether the match worked or not, and are not in this case extracting out the terms that the evars unified with for use.
However, if no test tactic is used, it might be possible to extract the evar bindings in the tactic to run when the shape matches, which gets even more of the functionality of match. Although how would one express that? Maybe something like:
shape (f ?[E1] ?[E2] = g ?E2 ?E1) tac (?E1, ?E2).
Hmmm... Maybe the real answer is to have an interactive-capable macro preprocessor that can sub "match goal with X |- _ => Y end" for "shape(X, Y)". Do interactive-capable macro preprocessors exist?
-- Jonathan
- [Coq-Club] Globally-nameless tactics: Getting rid of the verbose Ltac [match goal with] construct, Jason Gross, 01/24/2015
- Re: [Coq-Club] Globally-nameless tactics: Getting rid of the verbose Ltac [match goal with] construct, Jonathan Leivent, 01/24/2015
- Re: [Coq-Club] Globally-nameless tactics: Getting rid of the verbose Ltac [match goal with] construct, Emile Lunardon, 01/25/2015
- Re: [Coq-Club] Globally-nameless tactics: Getting rid of the verbose Ltac [match goal with] construct, Jason Gross, 01/25/2015
- Re: [Coq-Club] Globally-nameless tactics: Getting rid of the verbose Ltac [match goal with] construct, Jonathan Leivent, 01/25/2015
- Re: [Coq-Club] Globally-nameless tactics: Getting rid of the verbose Ltac [match goal with] construct, Jonathan Leivent, 01/26/2015
- Re: [Coq-Club] Globally-nameless tactics: Getting rid of the verbose Ltac [match goal with] construct, Jonathan Leivent, 01/27/2015
