Re: [Coq-Club] Globally-nameless tactics: Getting rid of the verbose Ltac [match goal with] construct
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Globally-nameless tactics: Getting rid of the verbose Ltac [match goal with] construct
- Date: Sun, 25 Jan 2015 05:51:48 +0100
UNSUBSCRIBE
2015-01-24 16:33 GMT+01:00 Jonathan Leivent <jonikelee AT gmail.com>:
I wasn't able to duplicate the match feature of named pattern variables with any combo of open_constr and uconstr, at least not without using evars in their place (which is not as good as one can easily leave unsolved evars as a result).
On 01/24/2015 03:11 AM, Jason Gross wrote:
Hi,
In case others may find this discovery interesting (if you have not already
made it yourselves):
It is possible to mostly eliminate the verbose [match goal with ... end]
construct in trunk/8.5 by using the following tactic:
Ltac hyp := multimatch goal with H : _ |- _ => constr:H end.
Note that [let H := hyp in ... ] will automatically backtrack across
failures of subsequent tactics, due to [multimatch]:
Goal False -> True -> False -> True.
intros.
let H := hyp in exact H.
Using open_constr and uconstr tactic notations, I presume the other
features of match (pattern matching on the body and the type) can be
duplicated with shorter syntax, too.
-Jason
Which is one reason why I was asking you about those other Tactic arg notations that are undocumented.
-- Jonathan
- [Coq-Club] Globally-nameless tactics: Getting rid of the verbose Ltac [match goal with] construct, Jason Gross, 01/24/2015
- Re: [Coq-Club] Globally-nameless tactics: Getting rid of the verbose Ltac [match goal with] construct, Jonathan Leivent, 01/24/2015
- Re: [Coq-Club] Globally-nameless tactics: Getting rid of the verbose Ltac [match goal with] construct, Emile Lunardon, 01/25/2015
- Re: [Coq-Club] Globally-nameless tactics: Getting rid of the verbose Ltac [match goal with] construct, Jason Gross, 01/25/2015
- Re: [Coq-Club] Globally-nameless tactics: Getting rid of the verbose Ltac [match goal with] construct, Jonathan Leivent, 01/25/2015
- Re: [Coq-Club] Globally-nameless tactics: Getting rid of the verbose Ltac [match goal with] construct, Jonathan Leivent, 01/26/2015
- Re: [Coq-Club] Globally-nameless tactics: Getting rid of the verbose Ltac [match goal with] construct, Jonathan Leivent, 01/27/2015
