- From: Wouter Geraedts <radboud AT woutergeraedts.nl>
- To: coq-club AT inria.fr
- Subject: [Coq-Club] Coq Standard Library XML output
- Date: Mon, 26 Jan 2015 14:16:28 +0100
Hello,
I am attempting to extract the XML:ACIC representation of the Coq standard library. Ideally I would like to have a separate XML file per .v file.
I have tried several approaches, of which the two most successful are:
(1) adding -xml to the COQ_XML variable in Makefile.build as suggested at the documentation + Mowgli documentation.
(2) running 'bin/coqtop.opt -boot -xml -nois -compile Datatypes' and similar as suggested here:
http://comments.gmane.org/gmane.science.mathematics.logic.coq.club/4016
Approach (1) dumps all XML to stdout. This is not ideal as this is mixed with various output from the Coq build process. Declaring COQ_XML_LIBRARY_ROOT should write separate XML files to this root folder.
This approach (1b) however fails, with coqdoc attempting to read from empty .v files which are deployed to the COQ_XML_LIBRARY_ROOT-folder. Oddly the following succeeds:
- first building without the COQ_XML_LIBRARY_ROOT declaration
- aborting midway
- building with COQ_XML_LIBRARY_ROOT
This succeeds up to the point of the abort. Looking at the file diff I only see some .glob files deleted after running the first pass. Letting the first pass complete before running the second pass results in the same problems as if the first pass was never run.
Approach (2) does not yield any output to stdout or file. It just runs and returns to the commandline.
I am running coq-8.4pl5 from source on Ubuntu 14.04 x64.
Any help will be appreciated.
Greetings,
Wouter Geraedts
- [Coq-Club] Coq Standard Library XML output, Wouter Geraedts, 01/26/2015
