coq-club - [Coq-Club] Grouping several canonical structures in one record - strange effect of Canonical Structure command
  • From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: [Coq-Club] Grouping several canonical structures in one record - strange effect of Canonical Structure command
  • Date: Mon, 26 Jan 2015 15:27:07 +0000
  • Accept-language: de-DE, en-US
Dear Coq Users,
I try to put several canonical structures, e.g. equality, choice, countable and finite plus the required collateral, into a record, so that I can discharge all structure at once with a single ltac script. But somehow I cannot manage to make use of the structures defined in a record with a canonical structure command. See e.g. the below sample (modified from the manual). I don’t understand why the canonical projections involve the projection functions of the structure (like msCarrier) rather than the contents of the structure (like nat). Eval compute in nat_setoid results in the right thing.
Thanks & best regards,
Michael
P.S.: I am still at 8.4pl5, but I am working on switching to 8.5
(*********** Example Code ***********)
Require Import Relations.
Require Import EqNat.
Structure Setoid : Type :=
  sCarrier      :> Set;
  sEqual        : relation sCarrier;
  sEqualIsEquiv : equivalence sCarrier sEqual
Record MultiStruct : Type :=
msCarrier      : Set;
  msEqual        : relation msCarrier;
  msEqualIsEquiv : equivalence msCarrier msEqual;
  msSetoid       := Build_Setoid msCarrier msEqual msEqualIsEquiv
Axiom eq_nat_equiv : equivalence nat eq_nat.
Definition multistruct_nat := Build_MultiStruct nat eq_nat eq_nat_equiv.
Canonical Structure nat_setoid := msSetoid multistruct_nat.
Print Canonical Projections.
(* Results in
msEqualIsEquiv <- sEqualIsEquiv ( nat_setoid )
msEqual <- sEqual ( nat_setoid )
msCarrier <- sCarrier ( nat_setoid )
