- From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] color info from coqdoc and .vo from coqtop
- Date: Mon, 2 Feb 2015 18:40:20 -0500
Here is a much simpler question :
The first line of the .glob file probably contains a hash of the .v file.
Does someone know which algorithm is used for this and what the parameters are?
Thanks,
-- Abhishek
http://www.cs.cornell.edu/~aa755/On Sat, May 24, 2014 at 2:50 PM, Abhishek Anand <abhishek.anand.iitg AT gmail.com> wrote:
Sorry for the late response. My responses are below:For syntax highlighting, wouldn’t it be easier to use the *.glob file ?Is there a (semi) formal description of the syntax and semantics of the *.glob file?I could not make a confident-enough guess, especially about its semantics.I do not know the details on how coqtop -ideslave works, but as an
interpreter, I guess it does not expect an end of file, and if you were
to add an "end of file" command to get the .vo files, then it would be
a .vo of an interactive session, which may be different from the
contents of the .v file. For instance, if the .vo files stores a hash
of the .v file, then as I do not think that the coqtop process receives
the layout of the file, you could be in a situation where the .vo file
you would get with coqc would differ from what your interactive session
would get. Same thing if the session does not send all the contents of
the file, or sends extra commands.
How about offloading the job of hash calculation to the IDE? The end-of-filecommand could provide the hash as an argument.The implementation of the "Require Import/Export" commands alreadychecks the correctness of the hash in the *.vo file w.r.t the corresponding *.v file, doesn't it?(I remember being forced to recompile my *.v files even when I merely changed some comments.)I agree that in the general case, IDEs might need to employ sophisticated algorithms todetermine the correct hash. But it should be simple in my specific use case asI need the file B.vo only if B.v (in my example) had no errors.
In that case, my plugin/IDE will sequentially send the entire contents and noother extra commands.Thanks,-- Abhishekhttp://www.cs.cornell.edu/~aa755/
- Re: [Coq-Club] color info from coqdoc and .vo from coqtop, Abhishek Anand, 02/03/2015
