coq-club - RE: [Coq-Club] Applying a simplified hypothesis gives the original hypothesis in the proof term
  • From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: RE: [Coq-Club] Applying a simplified hypothesis gives the original hypothesis in the proof term
  • Date: Mon, 2 Feb 2015 13:07:24 +0000
  • Accept-language: de-DE, en-US
Dear Arnaud,
thanks a lot, very helpful!
Best regards,
Michael
From: arnaud.spiwack AT gmail.com [mailto:arnaud.spiwack AT gmail.com] On Behalf Of Arnaud Spiwack
Sent: Monday, February 02, 2015 1:39 PM
To: Coq Club
Subject: Re: [Coq-Club] Applying a simplified hypothesis gives the original hypothesis in the proof term
This should be what you are after:
Definition x : list nat.
  let h := constr:([1;2;3] ++ [4;5;6]) in
  let h' := eval compute in h in
  set (H:= h').
  exact H.
Defined.
On 2 February 2015 at 10:54, Soegtrop, Michael <michael.soegtrop AT intel.com> wrote:
Dear Coq users,
when I simplify a hypothesis and then apply it, the proof term contains the original unsimplified hypothesis:
Require Import List.
Open Scope list_scope.
Import ListNotations.
Definition a := [1;2;3].
  set (H:= [1;2;3] ++ [4;5;6] ).
  compute in H.
  exact H.
Defined.
Print x. (* Results in x = let H := [1; 2; 3] ++ [4; 5; 6] in H : list nat *)
This is a bit inconvenient, especially in connection with the new $( )$ syntax.
Of cause I can use "Eval compute in" or similar outside of $( )$ but in some cases I want to be more selective in how to simplifiy which term.
I wonder if there is a way to get the simplified proof term in the proof term.
Btw.: "Eval compute in" doesn't work with "Instance", which might be a useful feature in connection with $( )$.
Best regards,
Michael
