- From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] name conflicts between coq libraries
- Date: Wed, 04 Feb 2015 18:15:23 +0100
On 04/02/2015 18:04, Pierre Courtieu wrote:
Hi Frédéric, here is what I understand, people will correct me if I am wrong.
This is a complex question since you may not be the author of the
libraries. Ideally each library should be compiled with option -R
If the libraries already work (when installed separately in user-contrib), they presumably were compiled using -R. Coq would be unable to load them otherwise, if I am not mistaken.
(or the new -Q option, but it is broken currently in 8.5beta).
Oh?
Then compiling L1 should give for example:
coqc -R L1 L1 L1/F.v
same for L2:
coqc -R L2 L2 L2/F.v
and the two "make install" should do the equivalent of:
cp L1/F.vo lib/coq/user-contrib/L1/
cp -r L2/F.vo lib/coq/user-contrib/L2/
Then "L1.F" and "L2.F" should work OK.
Of course the libraries need to be adapted to these compilation
options, they should "Require L1.F" themselves for example.
Only if they are being compiled using -Q. If they are compiled using -R, they do not need to (unless there is an ambiguity inside a library itself).
Best regards,
Guillaume
- [Coq-Club] name conflicts between coq libraries, Frédéric Blanqui, 02/04/2015
- Re: [Coq-Club] name conflicts between coq libraries, Jason Gross, 02/04/2015
- Re: [Coq-Club] name conflicts between coq libraries, Pierre Courtieu, 02/04/2015
- Re: [Coq-Club] name conflicts between coq libraries, Guillaume Melquiond, 02/04/2015
- Re: [Coq-Club] name conflicts between coq libraries, Frédéric Blanqui, 02/04/2015
