- From: Frédéric Blanqui <frederic.blanqui AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] name conflicts between coq libraries
- Date: Wed, 04 Feb 2015 21:25:22 +0100
Le 04/02/2015 19:04, Pierre Courtieu a écrit :
2015-02-04 18:31 GMT+01:00 Frédéric BlanquiGood to hear that because it doesn't seem a desirable feature since it exposes the internal file structure of the library to the outside: renaming a directory or moving a file into another directory will have an impact to all developments depending on this library. Not fixing this bug may lead people to use a flat file structure for their libraries which does not seem very nice. Frédéric.
<frederic.blanqui AT inria.fr>:
Hello.True. It looks like a bug. Note that D.F works however (unless hidden
Thank you for your answers.
However, I notice that, if the file F.v of L1 is in a subdirectory, say D,
then L1.F does not work. Instead we need to use L1.D.F.
by another D).
P.
Best regards,
Frédéric.
- [Coq-Club] name conflicts between coq libraries, Frédéric Blanqui, 02/04/2015
- Re: [Coq-Club] name conflicts between coq libraries, Jason Gross, 02/04/2015
- Re: [Coq-Club] name conflicts between coq libraries, Pierre Courtieu, 02/04/2015
- Re: [Coq-Club] name conflicts between coq libraries, Guillaume Melquiond, 02/04/2015
- Re: [Coq-Club] name conflicts between coq libraries, Frédéric Blanqui, 02/04/2015
