Re: [Coq-Club] Announcement: Tool for enabling better Coq 8.5 parallization on existing Coq developments
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Announcement: Tool for enabling better Coq 8.5 parallization on existing Coq developments
- Date: Sat, 07 Feb 2015 19:26:51 -0500
On 02/07/2015 04:55 PM, Jason Gross wrote:
.. If you want
to do this on the first run of the file, too, you must use [Proof using
<variables to be used in the proof>].
I guess I don't understand the behavior of [Proof using]: How is [Proof using] important to proof parallelism, if the [Proof using] declaration is only processed at Qed time (to determine if the proof obeyed the restriction or not, and to abstract over only the used variables)? Was [Proof using] changed in 8.5 to do earlier processing?
-- Jonathan
- [Coq-Club] Announcement: Tool for enabling better Coq 8.5 parallization on existing Coq developments, Jason Gross, 02/07/2015
- Re: [Coq-Club] Announcement: Tool for enabling better Coq 8.5 parallization on existing Coq developments, Jonathan Leivent, 02/08/2015
- Re: [Coq-Club] Announcement: Tool for enabling better Coq 8.5 parallization on existing Coq developments, Pierre Courtieu, 02/08/2015
- Re: [Coq-Club] Announcement: Tool for enabling better Coq 8.5 parallization on existing Coq developments, Enrico Tassi, 02/08/2015
