coq-club - Re: [Coq-Club] How to obtain the statement "n = S n'" within a match?
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] How to obtain the statement "n = S n'" within a match?
  • Date: Sun, 8 Feb 2015 01:44:45 +0100
2015-02-08 0:33 GMT+01:00 Holden Lee <holdenlee AT alum.mit.edu>:
I define "strong" recursion for natural numbers:
Definition strong_rec (P: nat -> Type) :
  (forall n: nat,
    (forall m: nat, (m<n) -> P m) -> P n) -> (forall m: nat, P m).
Now I try to define a function to convert from unary to binary:
Definition nat_to_bin : (nat -> bin) :=
strong_rec (fun _ => bin) (fun n => (fun F =>
  match n with
    | O => O'
    | S n' =>
      match (div2rem n) with
        | (x, O) => T (F (fst (div2rem (S n'))) (div2smaller n'))
        | (x, S y) => ST (F (fst (div2rem (S n'))) (div2smaller n'))
      end
  end)).
Basically I define nat_to_bin n in terms of nat_to_bin (n/2)
Here div2smaller n' is a proof that (S n')/2<S n' so that we can use strong_rec.
Lemma div2smaller:
  forall n, fst (div2rem (S n))<S n.
However this gives the error
Error:
In environment
n : nat
F : forall m : nat, m < n -> bin
n' : nat
x : nat
n0 : nat
The term "div2smaller n'" has type "fst (div2rem (S n')) < S n'"
 while it is expected to have type "fst (div2rem (S n')) < n".
How can I tell Coq that n=S n'?
​That is dependent pattern matching.
First of all, generalize over n: the type of "F" probably contains references to "n" and you want it to either depend on "O", or depend on "S n'"
The default behavior is:​
strong_rec (fun _
=> bin) (fun n =>
  match n
with
    | O =>
​fun (F : forall m, (m<O)
​ bin​
O'
    | S n' =>
​fun (F : forall m, (m<S n')
​ bin​
      end
  end).
At this point, it is possible that Coq complains about branches having different types. If this is the case, simply use some extended match construction.
strong_rec (fun _
=> bin) (fun n =>
  match n
 ​as x return (forall m, m<x -> bin) -> bin
with
    | O =>
​ bin​
O'
    | S n' =>
​ bin​
      end
  end).
​With that Coq has enough type information.​
For reference here is the definition for bin:
Inductive bin : Type :=
   | O' : bin
   | T : bin -> bin (*twice*)
   | ST: bin -> bin. (*one more than twice*)
Thanks,
Holden
