- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] selective zeta reduction
- Date: Tue, 10 Feb 2015 18:05:12 -0500
Given a term, is there a way to do selective zeta reduction, so that only certain local definitions are reduced? For example, consider a term like:
let x:=1 in let y:=2 in f x y
is there a way to do zeta reduction only on y, to end up with:
let x:=1 in f x 2
I'm not even sure how one would pick out which local definition to target - perhaps by its value or type. Even if there was just a way to reduce only the outermost local definition, that could perhaps be used to build a more general approach.
Is there anything along these lines in Coq?
-- Jonathan
- [Coq-Club] selective zeta reduction, Jonathan Leivent, 02/11/2015
- Re: [Coq-Club] selective zeta reduction, Cedric Auger, 02/11/2015
- Re: [Coq-Club] selective zeta reduction, Jason Gross, 02/11/2015
