- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] selective zeta reduction
- Date: Wed, 11 Feb 2015 03:49:10 -0500
How about this:
Goal forall f, let x:=1 in let y:=2 in f x y.
Proof.
intro.
match goal with
| [ |- appcontext G[let x := ?v in @?P x] ]
=> let G' := context G[P v] in
change G';
cbv beta
end.
I don't think it works under binders, though...
On Wed, Feb 11, 2015 at 3:44 AM, Cedric Auger <sedrikov AT gmail.com> wrote:
If I remember well, when you have a definition in your context, for example given by something like "set (a:=term).", when you revert this hypothesis, you end up with a let binding in the goal. ("revert a." produces "let a := term in …"). Maybe that the tactic language (I hardly ever use it) can pattern match let bindings to do the reverse. With an "unset" tactic, you could stack/unstack definitions. Then the "subst" tactic (maybe unfold as well?) would allow you to unfold the let bindings and have a zeta reduction (but from the hypothesis-definitions, not directly from the goal).2015-02-11 0:05 GMT+01:00 Jonathan Leivent <jonikelee AT gmail.com>:Given a term, is there a way to do selective zeta reduction, so that only certain local definitions are reduced? For example, consider a term like:
is there a way to do zeta reduction only on y, to end up with:
let x:=1 in f x 2
I'm not even sure how one would pick out which local definition to target - perhaps by its value or type. Even if there was just a way to reduce only the outermost local definition, that could perhaps be used to build a more general approach.
Is there anything along these lines in Coq?
-- Jonathan
- [Coq-Club] selective zeta reduction, Jonathan Leivent, 02/11/2015
- Re: [Coq-Club] selective zeta reduction, Cedric Auger, 02/11/2015
- Re: [Coq-Club] selective zeta reduction, Jason Gross, 02/11/2015
