- From: Matej Kosik <5764c029b688c1c0d24a2e97cd764f AT gmail.com>
- To: coq-club AT inria.fr
- Subject: [Coq-Club] a question about 'case' tactic (used with an inductive predicate)
- Date: Wed, 11 Feb 2015 19:37:30 +0000
Hi,
While continuing the quest to understand what 'case' tactic means, I have
tried this:
Inductive even : nat -> Prop :=
| even_O : even 0
| even_SS : forall n : nat, even n -> even (S (S n)).
and then:
(* the goal itself is pointless --- I am just curious about 'case'
tactic *)
Goal even 5 -> even 7.
Proof.
intro H.
case H.
I see that Coq generates two subgoals:
even 2
forall n : nat, even n -> even (S (S (S (S n))))
In this particular case, I am not so much interested whether the subgoals are
provable (they are) and how do the subproofs look like (trivial)
but I would like to understand how did Coq computed these subgoals.
(presumably from the original goal, the context and the chosen tactic)
Does anyone know?
Thanks a lot in advance for help with this.
Matej
- [Coq-Club] a question about 'case' tactic (used with an inductive predicate), Matej Kosik, 02/11/2015
- Re: [Coq-Club] a question about 'case' tactic (used with an inductive predicate), Cedric Auger, 02/11/2015
