Re: [Coq-Club] a question about 'case' tactic (used with an inductive predicate)
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] a question about 'case' tactic (used with an inductive predicate)
- Date: Wed, 11 Feb 2015 22:52:23 +0100
2015-02-11 20:37 GMT+01:00 Matej Kosik <5764c029b688c1c0d24a2e97cd764f AT gmail.com>:
Hi,
While continuing the quest to understand what 'case' tactic means, I have tried this:
Inductive even : nat -> Prop :=
| even_O : even 0
| even_SS : forall n : nat, even n -> even (S (S n)).
and then:
(* the goal itself is pointless --- I am just curious about 'case' tactic *)
Goal even 5 -> even 7.
Proof.
intro H.
case H.
I see that Coq generates two subgoals:
even 2
forall n : nat, even n -> even (S (S (S (S n))))
In this particular case, I am not so much interested whether the subgoals are provable (they are) and how do the subproofs look like (trivial)
but I would like to understand how did Coq computed these subgoals.
(presumably from the original goal, the context and the chosen tactic)
Does anyone know?
Yes:
In your hypothesis, you have:
H : even (S (S (S (S (S O)))))
and your goal is:
even (S (S (S (S (S (S (S O)))))))
When you run "case H", Coq will replace all occurrences of the index (the nat in "nat -> Prop" of even) it finds in the goal (other hypotheses are not affected, unless one of them uses directly H, in which case an error is returned; this is the main difference I see with destruct, where all hypotheses can be affected even if they do not use H).
Thus you could think of case as a "two steps tactic".
First it abstract its index (note that parameters, ie. arguments left of ':' in the inductive definition, are unaffected), then it replaces it with what it can find in the constructors of the inductives.
Intermediate step:
H : even <Hole 0>
and your goal is:
even (S (S <Hole 0>))
First case (replace <Hole 0> with O as told by the even_O constructor):
|- even (S (S O)) (* ie. even 2 *)
Second case (replace <Hole 0> with S (S n) as told by the even_SS constructor, needs introduction of n and even n):
|- forall n, even n -> even (S (S (S (S n))))
Thanks a lot in advance for help with this.
Matej
- [Coq-Club] a question about 'case' tactic (used with an inductive predicate), Matej Kosik, 02/11/2015
- Re: [Coq-Club] a question about 'case' tactic (used with an inductive predicate), Cedric Auger, 02/11/2015
