- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Equality proof of a simple computation
- Date: Mon, 16 Feb 2015 23:26:54 -0800
You can use even_odd_dec for the even/odd check. If you're dealing with natural numbers, you still need general recursion to recursively call the function with x/2, as Adam pointed out.
Note that if you use integers instead of natural numbers, the x/2 recursion is easier. Integers are already stored in binary in Coq.On Mon, Feb 16, 2015 at 12:49 PM, Adam Chlipala adamc-at-csail.mit.edu |coq-club/Example Allow| <qhp3ztn3ot AT sneakemail.com> wrote:
You might find it helpful to read Chapter 7 of CPDT <http://adam.chlipala.net/cpdt/>, which explains several approaches to general-recursive function definitions in Coq. There's going to be a catch, no matter which method you choose!
On 02/16/2015 03:36 PM, Jakub Arnold wrote:
Hey guys,
I've came across a few excercises in one of my classes and thought I could try proving them in Coq, but I can't find a way to represent them. The simplest one looks like this.
Prove that the following function does multiplication on natural numbers
f(x,y) := if x = 0 then 0else if (x is even) then 2 * f(x/2, y)else 2 * f(x/2, y) + y
I've managed to find the Arith.Div2.div2 function, which seems it could take care of the division, but I'm not really sure how to represent this as a Fixpoint, since the conditional requires a bool, but even is a Prop, though what I'm trying to prove feels more like a computation than a Prop.
Thanks for any tips! Sorry if this question is too easy, this is my first post on the mailing list.
- [Coq-Club] Equality proof of a simple computation, Jakub Arnold, 02/16/2015
- Re: [Coq-Club] Equality proof of a simple computation, Adam Chlipala, 02/16/2015
- Re: [Coq-Club] Equality proof of a simple computation, Kyle Stemen, 02/17/2015
- Re: [Coq-Club] Equality proof of a simple computation, Michel Levy, 02/17/2015
