coq-club - Re: [Coq-Club] Equality proof of a simple computation
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Equality proof of a simple computation
  • Date: Tue, 17 Feb 2015 16:46:36 +0100
On 16/02/2015 21:36, Jakub Arnold wrote:
Hey guys,
I've came across a few excercises in one of my classes and thought I could try proving them in Coq, but I can't find a way to represent them. The simplest one looks like this.
Prove that the following function does multiplication on natural numbers
f(x,y) := if x = 0 then 0
             else if (x is even) then 2 * f(x/2, y)
                     else 2 * f(x/2, y) + y
I've managed to find the Arith.Div2.div2 function, which seems it could take care of the division, but I'm not really sure how to represent this as a Fixpoint, since the conditional requires a bool, but even is a Prop, though what I'm trying to prove feels more like a computation than a Prop.
Thanks for any tips! Sorry if this question is too easy, this is my first post on the mailing list.
Jakub
The main difficulty is to write in Coq the definition of f.
I give first the librairies where you will find the definition of div2 : nat -> nat, even : nat -> bool, log2 : nat -> nat.
Require Import Coq.Arith.Div2.
(* div2 *)
Require Import Coq.Numbers.Natural.Peano.NPeano.
(* even  log2*)
But there is another difficulty. In Coq, you should write the recursive function with a "clearly" decreasing argument, for example (S k) decreases in k.
But it's not clear to Coq that x/2 (i.e. div2 x) < x.
What decreases is the "binary" length of x. So I suggest to introduce this length as a third argument.
f(x,y) = g(1+log2 x,x,y)
g(l,x, y):= if l=0 then 0 else if (x is even) then 2*g(l-1,x/2,y) else 2*g(l-1,x/2,y)+y
It's easy to translate, with a match _expression_, the definition of g in Coq, with the first argument clearly decreasing.
email : michel.levy1948 AT gmail.com
http://membres-liglab.imag.fr/michel.levy
