- From: Tahina Ramananandro <ramananandro AT reservoir.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] attempting to de-convoy a function via rewrite doesn't work
- Date: Fri, 20 Feb 2015 13:21:21 -0500
It looks like a misbehavior (bug or misunderstanding) of `rewrite ... in (value of f)'. Here is a minimal example that has nothing to do with convoy pattern and that fails likewise, in Coq 8.4pl4 as well as in Coq 8.5beta.
Goal forall A (a1 a2: A)
(EQ: a1 = a2),
let f := a1 in True.
intros.
rewrite EQ in (value of f).
Error: Found no subterm matching "a1" in f.
Hope this helps,
On Fri, Feb 20, 2015 at 1:07 PM, Jonathan Leivent <jonikelee AT gmail.com> wrote:
Sometimes, tactics like destruct produce proof terms that, while thoroughly reduced, aren't as simple as possible due to over-zealous use of convoy patterns. In one particular case, I tried to simplify such a function with a rewrite rule - but it doesn't work. What am I doing wrong?
Here's the rewrite rule, showing the convoy-pattern version of the function as the lhs of the rewrite equality and the simplification as the rhs:
Lemma decon :
forall (n : nat) A R (f0 : A -> R) (fSn : A -> nat -> R),
(fun a : A => match n with
| 0 => fun _ : A => f0 a
| S n' => fun _ : A => fSn a n'
end a) =
| 0 => f0 a
| S n' => fSn a n'
end).
Proof.
intros.
destruct n; reflexivity.
Qed.
But, the rewrite doesn't work:
Require Setoid.
Goal forall (n : nat) A R (f0 : A -> R) (fSn : A -> nat -> R),
let f := (fun a : A => match n with
end a) in True.
intros.
rewrite (decon n A R f0 fSn) in (value of f).
produces the error:
Error:
Found no subterm matching "fun a : A =>
match n with
end a" in f.
Which, even with Set Printing All, is an exact match for the body of f.
-- Jonathan
Tahina Oliver Ramananandro, Ph. D.
Senior Engineer, Advanced Compilers and Formal Verification
Reservoir Labs, Inc.
632 Broadway, Suite 803
New York, NY 10012
USA
Phone: +1 (212) 780-0527 ext. 157
E-mail: ramananandro AT reservoir.com
- [Coq-Club] attempting to de-convoy a function via rewrite doesn't work, Jonathan Leivent, 02/20/2015
- Re: [Coq-Club] attempting to de-convoy a function via rewrite doesn't work, Tahina Ramananandro, 02/20/2015
- Re: [Coq-Club] attempting to de-convoy a function via rewrite doesn't work, Jonathan Leivent, 02/20/2015
