coq-club - Re: [Coq-Club] Listing all known identifiers, without their types
  • From: Clément Pit--Claudel <clement.pit AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Listing all known identifiers, without their types
  • Date: Fri, 20 Feb 2015 13:17:10 -0500
Thanks for that suggestion.
It's an interesting fallback, but it doesn't have the flexibility that I'm
looking for; in particular, it doesn't tell you which commands are accessible
at a given point in a proof, and under which name (depending on what you
[Require Import], symbols may be available under different names).
Clément.
On 02/19/2015 12:10 PM, Abhishek Anand wrote:
> One way to do auto-completion is to crawl the content of all relevant .glob
> files when the IDE starts.
> That way, you can also implement "jump to definition".
> In the .glob files, ignore the first 2 lines and then look for lines that
> start with one of the following:
> rec, proj, def, not ,...
> The last word of these lines are names of the identifier that got defined.
> One of the words
> in the middle specifies the byte offsets in the corresponding .v file where
> that identifier was defined.
> For example, consider the following line taken from a .glob file
> def 679:685 <> enqueue
> It says that the identifier enqueue got defined at between the byte offsets
> 679 and 685.
> 679 is the byte-offset you should jump to if the user wants to see the
> definition of enqueue.
> Regards,
> -- Abhishek
> http://www.cs.cornell.edu/~aa755/
> On Wed, Feb 18, 2015 at 6:16 PM, Clément Pit--Claudel
> <mailto:clement.pit AT gmail.com>>
> wrote:
> Hi all,
> Is there a way to list all identifiers known to Coq, without printing
> their type? Something similar to the output of [SearchPattern _], but with
> type information stripped out. That is, a way to get
> Mult.mult_plus_distr_l
> Mult.mult_succ_l
> Mult.mult_succ_r
> Mult.odd_even_lem
> Mult.mult_acc_aux
> instead of
> Mult.mult_plus_distr_l: forall n m p : nat, n * (m + p) = n * m + n
> * p
> Mult.mult_succ_l: forall n m : nat, S n * m = n * m + m
> Mult.mult_succ_r: forall n m : nat, n * S m = n * m + n
> Mult.odd_even_lem: forall p q : nat, 2 * p + 1 <> 2 * q
> Mult.mult_acc_aux: forall n m p : nat, m + n * p = Mult.mult_acc m
> p n
> I've pushed a basic implementation of such a feature to
> https://github.com/cpitclaudel/coq/commit/198b9c47dedf4fa3b2a95ab7102b2d2d4ada392f
> (it adds an option "Search Minimal", which when activated reduces the
> output of search commands to just names). It would be nice to have that
> feature in Coq, though! But perhaps I missed an existing option? Another
> possible direction would be to implement a [Dump Identifiers To File
> <path>] command, which would write all names to a separate files.
> A bit of context: such a command would be useful to get better
> completion support for Coq in Emacs: using the list of all known terms and
> theorems one could implement a nice autocompletion package. Unfortunately
> ProofGeneral currently has trouble dealing with the output of
> [SearchPattern _] when large libraries are loaded (e.g. Reals), because it
> uses regular expressions to find the next prompt (in my experiments,
> reading the full list of all defined terms with their types takes about 3s;
> patching PG to do a plain string search first takes it down to about 1.5s;
> without the types, it takes 50ms).
> Thanks!
> Clément.
