coq-club - Re: [Coq-Club] Listing all known identifiers, without their types
  • From: Clément Pit--Claudel <clement.pit AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Listing all known identifiers, without their types
  • Date: Fri, 20 Feb 2015 15:48:14 -0500
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 02/20/2015 03:20 PM, Pierre-Marie Pédrot wrote:
> That is strange, because trunk does understand that sort of parlance.
Ah, Indeed, it works for me too. A silly mistake. Are there examples of to
interoperate with this? I found a few minimal references online, but no
simple examples.
> What use case are you exactly hoping for?
I'm hoping to get better auto-completion support in proof-general. The idea
is that if I can get a list of known identifiers, I can feed that to
company-mode, and get suggestions as I type for theorem names. I have that
working currently, but with the plain coq toplevel parsing through the huge
output of SearchPattern takes a while.
The patch that I'm currently using solves this nicely by letting you
constrain the output of all search functions to just names instead of
names+types.
> I do not know the exact
> state of ProofGeneral, and I do not know if the latest version uses the
> XML protocol (which I doubt), but if that is the case, you're going to
> run into trouble...
I don't think PG uses XML. I'm not familiar at all with the XML protocol,
either; I'll look into this, thanks for the pointer!
Other than that, is there no way to list identifiers when the toplevel is
started with just coqtop? I think a feature to just list identifiers would be
useful, until PG transitions to the apparently better XLM-based interface at
least.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1
iQEcBAEBAgAGBQJU552OAAoJEC0HUjwO/okMaTgH/jX6J6xItGc6N2P9ICdAOIMV
qNpQt1iAXh3YK/DYp0vGd4PFr5UAqTcZm8/3U3Gv8vMefid7SuTZXPEFztRPiFBo
M9lr6Y4kDekIl1BxdTZej1RuYiMHSjIZqi/e93ObOGLnmGj1b1DSU5241SEdj5Uw
4NdGnHwqFGB2RZe1sVXMfF68PE5vOoJz3keY29P8Ie6UBvkvIYbHNw9JRR56lFxW
niQeaWZfG2HcjEnbjztlVYre39BsVUz6IDqVO3ou3f9CDAB78yap3VniP7L6X0aK
imKJ+o/orMqEnw+6mJYlZbF2paON6AoPE3qPogWMlT/3AAp/oVUuRZ1Z4xlOdtU=
=2Qg/
-----END PGP SIGNATURE-----
