coq-club - Re: [Coq-Club] Pierce Software Foundations. Runs fine in Coq 8.4, but error in 8.5.
  • From: Frédéric Blanqui <frederic.blanqui AT inria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Pierce Software Foundations. Runs fine in Coq 8.4, but error in 8.5.
  • Date: Tue, 24 Feb 2015 08:35:09 +0100
You can also use:
Set Implicit Arguments.
and remove the argument X:
Fixpoint length X (l:list X) :=
match l with
|nil => 0
|cons _ t => S (length t)
end.
Le 24/02/2015 07:31, Guillaume Melquiond a écrit :
On 24/02/2015 07:20, Sriram Srinivasan wrote:
Can someone explain why the following doesn't work in 8.5beta1?
Inductive list (X:Type) : Type :=
| nil : list X
| cons : X -> list X -> list X.
Fixpoint length (X:Type) (l:list X) : nat :=
match l with
|nil => 0
|cons h t => S (length X t)
end.
Error: The constructor nil (in type list) expects 1 argument.
Constructors and destructors are no longer separate in 8.5. Since the constructor nil takes an argument, the destructor nil also takes an argument. Since this argument is noninformative, it has to be "_".
match l with
| nil _ => 0
| cons _ h t => S (length X t)
end.
You can recover the old behavior by using
Set Asymmetric Patterns.
Best regards,
Guillaume
