coq-club - [Coq-Club] Weird installation error in OS X Mavericks
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Weird installation error in OS X Mavericks
  • Date: Tue, 24 Feb 2015 12:18:13 -0300
Hi club,
Apologies if this is not the right venue for this kind of questions
I installed Coq 8.4pl5 using Homebrew (brew install coq), but for some reason I cannot use the admit tactic. As far as I understand, admit is now built-in in Coq. I asked a colleague to check if it was available and indeed it was working on his machine, hence I assume it is some weird installation issue... Can anyone please point me to where is the issue happening?
I attach a small file with my interaction with coqtop and the actual error message.
Thanks
Ismael
ismael@Macintosh:~$ coqtop -v
The Coq Proof Assistant, version 8.4pl5 (February 2015)
compiled on Feb 24 2015 11:29:56 with OCaml 4.02.1
ismael@Macintosh:~$ coqtop -config
LOCAL=0
COQLIB=/usr/local/lib/coq/
DOCDIR=/usr/local/Cellar/coq/8.4pl5/share/doc/coq/
OCAMLDEP=ocamldep
OCAMLC=ocamlc
OCAMLOPT=ocamlopt
OCAMLDOC=ocamldoc
CAMLBIN=/usr/local/bin/
CAMLLIB=/usr/local/lib/ocaml/
CAMLP4=camlp5
CAMLP4BIN=/usr/local/bin/
CAMLP4LIB=/usr/local/Cellar/camlp5/6.12_2/lib/ocaml/camlp5
HASNATDYNLINK=true
Welcome to Coq 8.4pl5 (February 2015)
Coq < Definition foo (a:nat) (b:nat): nat := admit.
Toplevel input, characters 39-44:
Error: The reference admit was not found in the current environment.
Coq < Definition admit {T: Type} : T. Admitted.
1 subgoal
T : Type
T
admit is assumed
foo is defined
Coq <
