Re: [Coq-Club] Difference between [Proof using .] and [Proof using Type.] in 8.5
- To: Coq-Club Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Difference between [Proof using .] and [Proof using Type.] in 8.5
- Date: Mon, 23 Mar 2015 10:04:21 +0000
> [...] why do you put a lemma in a section if it uses no section variables
For [Local] behavior
On Mon, Mar 23, 2015 at 8:00 AM, Enrico Tassi
<enrico.tassi AT inria.fr>
wrote:
> On Mon, Mar 23, 2015 at 12:29:16AM -0400, Jason Gross wrote:
>> Sometimes, [Set Suggest Proof Using] suggests [Proof using .], and
>> sometimes, it suggests [Proof using Type.]. The reference manual seems to
>> indicate that they are the same. Is there a difference between them, and,
>> if not, why does [Set Suggest Proof Using] sometimes choose one and
>> sometimes choose the other?
> They do work the same: the system uses only the variables occurring in
> the statement. I'd say the doc is correct.
> The code suggests "Proof using." when the section is empty (or the lemma
> uses no section hyps), and "Proof using Type." when all the used
> variables occur in the statement.
> The behavior of "Suggest..." is not intended. At some point the two
> syntaxes had different meaning, but then I changed my mind.
> Still the current behavior could be of some use: why do you put a lemma
> in a section if it uses no section variables? Maybe "Suggest..." should
> always print "..using." instead of "..Type." and give a warning in case
> the lemma has no reason to be in the section? What do you think?
> Thanks for spotting this one!
> Enrico Tassi
- [Coq-Club] Difference between [Proof using .] and [Proof using Type.] in 8.5, Jason Gross, 03/23/2015
- Re: [Coq-Club] Difference between [Proof using .] and [Proof using Type.] in 8.5, Enrico Tassi, 03/23/2015
- Re: [Coq-Club] Difference between [Proof using .] and [Proof using Type.] in 8.5, Randy Pollack, 03/23/2015
