- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] how to split lines in fail messages
- Date: Fri, 27 Mar 2015 18:52:29 -0400
Is there any way to compose a single fail message from multiple strings and terms with explicit line breaks inserted at certain points? I tried "\n" (eg. below) and various direct ascii characters, but they all just printed out without being interpreted as line breaks. Also, putting the fail args on separate lines doesn't change things.
fail 0 "mytactic failure:" term1 "\ndid not work with" term2
-- Jonathan
- [Coq-Club] how to split lines in fail messages, Jonathan Leivent, 03/27/2015
- Re: [Coq-Club] how to split lines in fail messages, Jason Gross, 03/28/2015
- Re: [Coq-Club] how to split lines in fail messages, Jonathan Leivent, 03/28/2015
