coq-club - Re: [Coq-Club] how to split lines in fail messages
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] how to split lines in fail messages
  • Date: Fri, 27 Mar 2015 22:30:28 -0400
On 03/27/2015 08:16 PM, Jason Gross wrote:
You can insert two linebreaks by guessing a value for the widest buffer
your users will have, and insert that many spaces, like:
fail 0 "aasdf" "
" "adsf".
If you can accept extra quotations, and a possible %string if string_scope
is closed, you can do
Require Import Coq.Strings.String.
Local Open Scope string_scope.
Definition NEWLINE := String (Ascii.Ascii false true false true false false
false false) EmptyString.
Goal True.
let nl := (eval unfold NEWLINE in NEWLINE) in
fail 0 "asdf" nl "asdf".
OK - so I guess the answer is "no".
It's the age of Twitter. All msgs should fit on 1 line. GWTP, else TMI.
- J
On Fri, Mar 27, 2015 at 6:52 PM, Jonathan Leivent
<jonikelee AT gmail.com>
wrote:
Is there any way to compose a single fail message from multiple strings
and terms with explicit line breaks inserted at certain points? I tried
"\n" (eg. below) and various direct ascii characters, but they all just
printed out without being interpreted as line breaks. Also, putting the
fail args on separate lines doesn't change things.
fail 0 "mytactic failure:" term1 "\ndid not work with" term2
-- Jonathan
