- To: coq-club AT inria.fr
- Subject: [Coq-Club] Pattern-matching a type
- Date: Tue, 5 May 2015 18:23:35 -0400
Hi,
I'm trying to write an "invariance principle" tactic. To illustrate, consider the following example.
(*You have 27 socks. Every day you take out 2 or put 2 in. Prove that you will never have 0 socks.*)
Inductive Socks : nat -> Prop :=
| begin : Socks 27
| putin : forall x, Socks x -> Socks (x+2)
| takeout : forall x, x>=2 -> Socks x -> Socks (x-2).
Theorem NonzeroSocks :
not (Socks 0).
Proof.
assert (forall x:nat, Socks x -> even x = false) as H.
intros x H.
induction H; admit. (*omitted*)
intro H0.
apply H in H0.
simpl in H0.
inversion H0.
End.
I want to write a tactic that does the boilerplate for this kind of proof.
(*ind_prop:A -> Prop, f:A -> Prop*)
Ltac invariance ind_prop f:=
let t := type of f in
let A := (match t with
| ?P -> ?Q => ?P
end) in
assert (forall x:A, ind_prop x -> f x) as H; [intros x H; induction H | intro H0; apply H in H0].
so that I can write "invariance Socks (fun n:nat => even n = false)."
However, Coq complains about the match statement in the middle.
Syntax error: [tactic:tactic_expr] expected after '=>' (in [match_rule]).
What's the proper way to write this?
Thanks,
Holden
- [Coq-Club] Pattern-matching a type, Holden Lee, 05/06/2015
- RE: [Coq-Club] Pattern-matching a type, Soegtrop, Michael, 05/06/2015
