coq-club - Re: [Coq-Club] Printing in Coq
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Printing in Coq
  • Date: Wed, 06 May 2015 13:33:05 -0400
On 05/06/2015 09:34 AM, Holden Lee wrote:
Thanks. Some follow-ups:
1. How do I print the type of H in the example? (?x=?y) How can I print
out the goal?
let HT:=type of H in idtac "The type of" H "is" HT
I have a tactic that I use to print out entire goals - it is very useful when debugging tactics:
Ltac vgoal :=
idtac; (*prevents early eval*)
match reverse goal with
| H : ?T |- _ =>
first[let v := eval cbv delta [H] in H in
idtac H ":=" v ":" T
|idtac H ":" T];
fail
| |- ?G =>
idtac "======"; idtac G; idtac ""
end.
2. Why does the statement
idtac "rewriting" H
work in Ltac but not in a normal proof body? The following gives Error:
H not found.
Theorem thm :
forall x, x=0 -> x+1=1.
Proof.
intros x H.
idtac "rewriting " H.
I would view that as a bug in Coq - but it is easily worked around by doing:
let H':=H in idtac "rewriting" H'.
3. I see the outputs when using the CoqIDE but not Emacs Proof General.
Is there a way to see them for Proof General?
You probably need a more recent version of Proof General. The Coq interface there has received a great deal of work recently. You can get the development version from :pserver:anon AT cvs.inf.ed.ac.uk:/disk/cvs/proofgen and stay up to date.
-- Jonathan
Thanks,
Holden
On Tue, May 5, 2015 at 6:46 PM, Jonathan Leivent
<jonikelee AT gmail.com>
wrote:
On 05/05/2015 06:25 PM, Holden Lee wrote:
How can I print in Coq? For example, What's the correct way to write this
so that the tactic prints what it's doing?
Ltac some_tactic:=
match goal with
| [H : ?x = ?y |- _] => print ("rewriting "++(show H)); rewrite H
The tactics idtac and fail both can be used to print info during proofs.
The example above becomes:
Ltac some_tactic :=
match goal with
| H : ?x = ?y |- _ => idtac "rewriting" H; rewrite H
More complicated: how can I print in backtracking proofs?
tactic1 := (...); if succeed then print "Tactic 1 succeeds" else print
"Tactic 1 fails."
(tactic1 || tactic2)
Ltac tactic1 := tryif (...) then idtac "Tactic 1 succeeds" else fail 0
"Tactic 1 fails".
-- Jonathan
