coq-club - Re: [Coq-Club] Printing in Coq
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Printing in Coq
  • Date: Wed, 6 May 2015 09:34:30 -0400
Thanks. Some follow-ups:
  1. How do I print the type of H in the example? (?x=?y) How can I print out the goal?
  2. Why does the statement
    idtac "rewriting" H
    work in Ltac but not in a normal proof body? The following gives Error: H not found.
    Theorem thm :
     forall x, x=0 -> x+1=1.
    Proof.
      intros x H.
      idtac "rewriting " H.
  3. I see the outputs when using the CoqIDE but not Emacs Proof General. Is there a way to see them for Proof General?
Thanks,
Holden
On Tue, May 5, 2015 at 6:46 PM, Jonathan Leivent <jonikelee AT gmail.com> wrote:
On 05/05/2015 06:25 PM, Holden Lee wrote:
How can I print in Coq? For example, What's the correct way to write this
so that the tactic prints what it's doing?
Ltac some_tactic:=
   match goal with
| [H : ?x = ?y |- _] => print ("rewriting "++(show H)); rewrite H
The tactics idtac and fail both can be used to print info during proofs.  The example above becomes:
Ltac some_tactic :=
   match goal with
   | H : ?x = ?y |- _ => idtac "rewriting" H; rewrite H
More complicated: how can I print in backtracking proofs?
   tactic1 := (...); if succeed then print "Tactic 1 succeeds" else print
"Tactic 1 fails."
   (tactic1 || tactic2)
Ltac tactic1 := tryif (...) then idtac "Tactic 1 succeeds" else fail 0 "Tactic 1 fails".
-- Jonathan
