- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] setoid rewriting -- naive questions
- Date: Thu, 7 May 2015 15:49:08 -0700
Matthieu,
After switching to 8.5 I decided to see if I can take advantage of your
bug fix to avoid Vector.cons argument reordering workaround I’ve used
before. To recap, I was using the following definitions to replace
Vector.cons with Vcons_reord which allowed me to rewrite its arguments:
Section VCons_p.
Definition Vcons_reord {A} {n} (t: vector A n) (h:A): vector A (S n) :=
Vcons h t.
Lemma Vcons_to_Vcons_reord: forall A n (t: vector A n) (h:A), Vcons h t ≡
Vcons_reord t h.
Admitted.
Global Instance Vcons_reord_proper `{Equiv A} n:
Proper (@vec_equiv A _ n ==> (=) ==> @vec_equiv A _ (S n))
(@Vcons_reord A n).
Admitted.
End VCons_p.
Now I get rid of this and defined Instance of vcons_proper as shown below and
tried to rewrite
Vcons directly. It works if I rewrite the first argument (of type A), but
does not allow me to rewrite
second one (of type (vector A n)). Here is example using your definitions
below:
Goal forall A `{Equiv A} `{!Setoid A}
(f : A -> A) (h: A) n (a b : vector A n) (Z : equiv a b) ,
equiv (Vcons h a) (Vcons h b).
Proof.
intros.
rewrite Z.
reflexivity.
Qed.
Any ideas why this is not working? Exact error message:
Tactic failure: setoid rewrite failed: Unable to satisfy the following
constraints:
UNDEFINED EVARS:
?X83==[A H Setoid0 f h n a b Z |- relation (vector A (S n))]
(internal placeholder) {r}
?X84==[A H Setoid0 f h n a b Z (do_subrelation:=do_subrelation)
|- Proper
(equiv ==>
?X83@{A:=A; A:=H; A:=Setoid0; A:=f; A:=h; A:=n; A:=a; A:=b;
A:=Z}) (Vector.cons A h n)] (internal placeholder) {p}
?X86==[A H Setoid0 f h n a b Z |- relation (vector A (S n))]
(internal placeholder) {r0}
?X87==[A H Setoid0 f h n a b Z (do_subrelation:=do_subrelation)
|- Proper
(?X83@{A:=A; A:=H; A:=Setoid0; A:=f; A:=h; A:=n; A:=a; A:=b;
A:=Z} ==>
?X86@{A:=A; A:=H; A:=Setoid0; A:=f; A:=h; A:=n; A:=a; A:=b;
A:=Z} ==> Basics.flip Basics.impl) equiv]
(internal placeholder) {p0}
?X88==[A H Setoid0 f h n a b Z
|- ProperProxy
A:=Z} (Vcons h b)] (internal placeholder) {p1}.
Sincerely,
Vadim
> On Nov 23, 2014, at 6:09 , Matthieu Sozeau
> <matthieu.sozeau AT inria.fr>
> wrote:
> Hello,
> generalized rewriting won’t let you rewrite the dependent
> index argument of vcons but it does support rewriting the other,
> non-dependent arguments in principle. After some investigation,
> I discovered a de Bruijn bug that prevented this rewriting in arguments
> prior to a dependent argument to succeed. It is now fixed in the trunk
> and the following works. Note the vcons_proper signature is using the
> [forall_relation] combinator which allows to state the signature for
> the (vector A k) argument of (Vcons A x k) and it’s codomain of type
> (vector A (S k)) for any k : nat.
> Require Import Setoid.
> Require Import Morphisms.
> Require Vector.
> Notation vector := Vector.t.
> Notation Vcons n t := (@Vector.cons _ n _ t).
> Class Equiv A := equiv : A -> A -> Prop.
> Class Setoid A `{Equiv A} := setoid_equiv:> Equivalence (equiv).
> Instance vecequiv A `{Equiv A} n : Equiv (vector A n).
> admit.
> Defined.
> Global Instance vcons_proper A `{Equiv A} :
> Proper (equiv ==> forall_relation (fun k => equiv ==> equiv))
> (@Vector.cons A).
> Proof. Admitted.
> Instance vecsetoid A `{Setoid A} n : Setoid (vector A n).
> Proof. Admitted.
> Goal forall A `{Equiv A} `{!Setoid A} (f : A -> A) (a b : A) (H : equiv a
> b) n (v : vector A n),
> equiv (Vcons a v) (Vcons b v).
> Proof.
> intros.
> rewrite H0.
> reflexivity.
> Qed.
> About the vecequiv vs. equiv issue in vcons_proper’s declaration, it
> happens
> because Equivalence vecequiv (needed to find a reflexivity proof for the v
> argument)
> cannot be inferred from the setoid_equiv + vecsetoid instances as @equiv ?A
> ?e does
> not unify with vecequiv. The following declarations make it work:
> Instance equiv_setoid A {e : Equiv A} {s : @Setoid A e} : Equivalence e.
> apply setoid_equiv.
> Qed.
> Typeclasses Transparent Equiv. (* This last bit is necessary to convert
> Equiv A and A -> A -> Prop *)
> But I would advise to stay with the [equiv] formulation.
> Hope this helps,
> — Matthieu
> On 21 nov. 2014, at 10:13, Vadim Zaliva
> <vzaliva AT cmu.edu>
> wrote:
>> With huge help from Daniel we have been able to work out a solution.
>> I will summarize my findings in case somebody interested. The main missing
>> part
>> was proving Proper for Vcons. It requires two things:
>> 1. Reordering Vcons arguments. I did this like this:
>> Definition VConsR {A} {n} (t: vector A n) (h:A): vector A (S n) := Vcons h
>> t.
>> Lemma ConsR_VConsR: forall A n (t: t A n) (h:A), Vcons h t ≡ VConsR t h.
>> Proof.
>> intros. reflexivity.
>> Qed.
>> 2. Proving 'Proper' instance:
>> Global Instance vconsR_proper `{Equiv A} n:
>> (@VConsR A n).
>> Proof.
>> split.
>> assumption.
>> unfold vec_equiv, Vforall2 in H0. assumption.
>> Qed.
>> Now to use commutativity in the original proof we can just do:
>> rewrite ConsR_VConsR.
>> rewrite commutativity.
>> My only remaining regret is that I have two to 2 steps to apply
>> commutativity to Vcons.
>> I guess this could be automated via custom tactics, but I have not even
>> started learning LTAC :)
>> Vadim
>>> On Nov 18, 2014, at 11:25 , Vadim Zaliva
>>> wrote:
>>> I am trying to prove following lemma:
>>> Lemma map2_setoid_comm `{Equiv B} `{Commutative B A}:
>>> forall n (a b: vector A n),
>>> (map2 f a b) = (map2 f b a).
>>> I am using Equiv and Commutative type classes from CoRN. For convenience
>>> I am also using VecUtil from CoLoR which provide several handy
>>> definitions for fixed-size vectors.
>>> Require Import abstract_algebra orders.minmax interfaces.orders.
>>> Require Import MathClasses.theory.rings.
>>> Require Import CoLoR.Util.Vector.VecUtil.
>>> Import VectorNotations.
>>> The equivalence used here (=) is 'equiv'. I was able to instantiate:
>>> Definition vec_equiv `{Equiv A} {n}: relation (vector A n) := Vforall2
>>> (n:=n) equiv.
>>> Instance vec_Equiv `{Equiv A} {n}: Equiv (vector A n) := vec_equiv.
>>> which permitted me to use reflexivity tactics to prove IH. Now I am trying
>>> to use 'commutativity' but no luck so far:
>>> 1 subgoals, subgoal 1 (ID 1405)
>>> B : Type
>>> H : Equiv B
>>> H0 : Equiv B
>>> A : Type
>>> f : A → A → B
>>> H1 : Commutative f
>>> n : nat
>>> a : vector A (S n)
>>> b : vector A (S n)
>>> IHn : ∀ a0 b0 : vector A n, map2 f a0 b0 = map2 f b0 a0
>>> Vcons (f (Vhead a) (Vhead b)) (map2 f (Vtail a) (Vtail b)) = map2 f b a
>>> As the next step I want rewrite LHS cons head by replacing (f (Vhead a)
>>> (Vhead b)) with (f (Vhead b) (Vhead a)) by commutativity. I could not
>>> make it work with any of rewrite tactics.
>>> I will appreciate if somebody would point me in the right direction.
>>> Thanks!
>>> Sincerely,
>>> Vadim
>> Sincerely,
>> Vadim Zaliva
>> CMU ECE PhD student
>> Mobile: +1(510)220-1060
>> Skype: vzaliva
Sincerely,
Vadim Zaliva
CMU ECE PhD candidate
Skype: vzaliva
- Re: [Coq-Club] setoid rewriting -- naive questions, Vadim Zaliva, 05/08/2015
- Re: [Coq-Club] setoid rewriting -- naive questions, Jason Gross, 05/08/2015
