- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] setoid rewriting -- naive questions
- Date: Thu, 7 May 2015 18:17:37 -0700
On May 7, 2015, at 16:13 , Jason Gross <jasongross9 AT gmail.com> wrote:You get more useful output if you [Set Typeclasses Debug], and then do [try rewrite Z]. The issues are:(?X84) you are missing a Vcons_proper instance; this works:Global Instance Vcons_proper A `{H:Equiv A} n a:Proper (@equiv (vector A (n)) (@vecequiv A H (n)) ==> equiv) (@Vcons A a n).Admitted.
Thanks for debug suggestion!
After 'Set Typeclasses Debug’ here is the output:
Debug: : no match for (Params H0 ?H1) , 0 possibilities
Debug: 1.1: (*external*) proper_subrelation on
(Proper (equiv ==> ?r) (Vector.cons A h n))
Debug: 1.1.1.1: (*external*) proper_reflexive on
(Proper ?R' (Vector.cons A h n))
Debug: 1.1.2.1: (*external*) unconvertible on
(Unconvertible (relation (vector A n -> vector A (S n)))
(equiv ==> ?r)%signature eq)
Debug: 1.1.3: no match for (subrelation eq (equiv ==> ?r)%signature)
, 1 possibilities
Debug: Backtracking after (*external*) unconvertible
Debug: Backtracking after (*external*) proper_reflexive
Debug: Backtracking after (*external*) proper_subrelation
Debug: 1.2: (*external*) proper_normalization on
Debug: 1.2.1.1: (*external*) normalizes on
(Normalizes (vector A n -> vector A (S n)) (equiv ==> ?r)%signature ?R1)
Debug: 1.2.1.1.1.1: (*external*) normalizes on
(Normalizes (vector A n) equiv (Basics.flip ?Goal3))
Debug: 1.2.1.1.2.1: (*external*) normalizes on
(Normalizes (vector A (S n)) ?r (Basics.flip ?Goal5))
Debug: 1.2.2.1: (*external*) class_apply @proper_flip_proper on
(Proper (Basics.flip (equiv --> Basics.flip ?r)%signature)
Debug: 1.2.2.1.1.1: (*external*) proper_subrelation on
(Proper (equiv --> Basics.flip ?r) (Vector.cons A h n))
Debug: 1.2.2.1.1.1.1: no match for (Proper ?R' (Vector.cons A h n))
, 6 possibilities
Debug: Backtracking after (*external*) class_apply @proper_flip_proper
Debug: 1.2.2.2: (*external*) proper_subrelation on
Debug: 1.2.2.2.1: no match for (Proper ?R' (Vector.cons A h n))
, 6 possibilities
Debug: Backtracking after (*external*) normalizes
Debug: Backtracking after (*external*) proper_normalization
Debug: 1.3: (*external*) proper_reflexive on
Debug: 1.3.1.1: apply @Equivalence_Reflexive on
(Reflexive (equiv ==> ?r)%signature)
Debug: 1.3.1.1.1: no match for (Equivalence (equiv ==> ?r)%signature)
, 1 possibilities
Debug: Backtracking after apply @Equivalence_Reflexive
Debug: 1.3.1.2: apply @PreOrder_Reflexive on
Debug: 1.3.1.2.1: no match for (PreOrder (equiv ==> ?r)%signature)
, 1 possibilities
Debug: Backtracking after apply @PreOrder_Reflexive
Toplevel input, characters 5-15:
> rewrite Z.
I do have Proper instance for Vcons defined as follows:
Global Instance vcons_proper A `{Equiv A} :
Proper (equiv ==> forall_relation (fun k => equiv ==> equiv))
(@Vector.cons A).
Proof. Admitted.
But it does not seems to be applicable here. I am trying to understand why.
I also tried to use your definition of Vcons_proper and it gives me error:
Error: Illegal application (Non-functional construction):
The _expression_ "Vcons A a" of type "vector Type (S ?n)"
cannot be applied to the term
"n" : "nat"
I am using latest build from v8.5 branch.
Sincerely,
Vadim Zaliva
Vadim Zaliva
CMU ECE PhD candidate
Mobile: +1(510)220-1060
Skype: vzaliva
- Re: [Coq-Club] setoid rewriting -- naive questions, Vadim Zaliva, 05/08/2015
- Re: [Coq-Club] setoid rewriting -- naive questions, Jason Gross, 05/08/2015
