- From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] coq8.5: "no constraint can apply on a dependent argument"
- Date: Fri, 8 May 2015 21:00:43 -0400
A small self-contained example would definitely help.
When rewrite fails, I often find it useful to directly invoke or apply eq_rect or eq_ind (these are automatically generated induction principles for the equality type).
If even that fails, I ask someone to help me with writing a dependent pattern match on the proof of equality (e.g. E1 in your case).
-- Abhishek
http://www.cs.cornell.edu/~aa755/On Fri, May 8, 2015 at 8:38 PM, Vadim Zaliva <vzaliva AT cmu.edu> wrote:
If there is any additional information I can provide to help to figure out what is causing this?
Some proofs which were working in 8.4 does not work in 8.5 because of this error and I do not
see anything wrong here. I suspect it might be a bug in 8.5 branch.
Vadim
> On May 7, 2015, at 12:43 , Vadim Zaliva <vzaliva AT cmu.edu> wrote:
> I am trying to port some of my proofs from 8.4 to 8.5 (I am using latest snapshot
> from git) and getting error message I have not encountered before:
> E1 : xa = ya
> E2 : xb = yb
> (Vtail xa, Vtail xb) = (Vtail ya, Vtail yb)
> rewrite E1, E2.
> Error: build_signature: no constraint can apply on a dependent argument
> What does it mean?
> Sincerely,
> Vadim Zaliva
> CMU ECE PhD candidate
> Mobile: +1(510)220-1060
> Skype: vzaliva
Sincerely,
Vadim Zaliva
Skype: vzaliva
- [Coq-Club] coq8.5: "no constraint can apply on a dependent argument", Vadim Zaliva, 05/07/2015
- Re: [Coq-Club] coq8.5: "no constraint can apply on a dependent argument", Vadim Zaliva, 05/09/2015
- Re: [Coq-Club] coq8.5: "no constraint can apply on a dependent argument", Abhishek Anand, 05/09/2015
- Re: [Coq-Club] coq8.5: "no constraint can apply on a dependent argument", Vadim Zaliva, 05/10/2015
- Re: [Coq-Club] coq8.5: "no constraint can apply on a dependent argument", Abhishek Anand, 05/10/2015
