- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] coq8.5: "no constraint can apply on a dependent argument"
- Date: Sat, 9 May 2015 19:49:15 -0700
On May 8, 2015, at 18:00 , Abhishek Anand <abhishek.anand.iitg AT gmail.com> wrote:A small self-contained example would definitely help.
Here is an example which works under 8.4 but gives an error on 8.5:
Require Import Setoid Morphisms Vector.
Class Equiv A := equiv : A -> A -> Prop.
Class Setoid A `{Equiv A} := setoid_equiv:> Equivalence (equiv).
Global Instance vec_equiv {A} `{Equiv A} {n}: Equiv (Vector.t A n). Admitted.
Global Instance vec_setoid A `{Setoid A} n : Setoid (Vector.t A n). Admitted.
Global Instance tl_proper1 {A} `{Equiv A} n:
Proper ((equiv) ==> (equiv))
(@tl A n).
Admitted.
Lemma test:
forall {A} `{Setoid A} n (xa ya: Vector.t A (S n)),
(equiv xa ya) -> equiv (tl xa) (tl ya).
Proof.
intros.
setoid_rewrite H1.
reflexivity.
Qed.
Under Coq 8.5 'setoid_rewrite' gives "Error: build_signature: no constraint can apply on a dependent argument”.
When rewrite fails, I often find it useful to directly invoke or apply eq_rect or eq_ind (these are automatically generated induction principles for the equality type).
Can you show me how to do this in example above? I would love to learn how to debug things like this. Thanks!
Sincerely,
Vadim Zaliva
Vadim Zaliva
CMU ECE PhD candidate
Mobile: +1(510)220-1060
Skype: vzaliva
- [Coq-Club] coq8.5: "no constraint can apply on a dependent argument", Vadim Zaliva, 05/07/2015
- Re: [Coq-Club] coq8.5: "no constraint can apply on a dependent argument", Vadim Zaliva, 05/09/2015
- Re: [Coq-Club] coq8.5: "no constraint can apply on a dependent argument", Abhishek Anand, 05/09/2015
- Re: [Coq-Club] coq8.5: "no constraint can apply on a dependent argument", Vadim Zaliva, 05/10/2015
- Re: [Coq-Club] coq8.5: "no constraint can apply on a dependent argument", Abhishek Anand, 05/10/2015
