- To: Coq Club <coq-club AT inria.fr>
- Subject: Re:[Coq-Club]
- Date: Fri, 15 May 2015 11:40:07 -0700
Hi, Nico --
I don't believe this is possible. If the type is embedded inside of a term, then that term could be opened up via Ltac, and then Ltac could construct a term using constr and avoid your check.
It is possible to express your restriction via arguments? For example, if you want a type function that requires a type with a decidable equality there are several ways to do it:
(* type class *)
Class EqDec (T : Type) : Type :=
{ eq_dec : forall a b : T, {a = b} + {a <> b} }.
Axiom M : forall T : Type, EqDec T -> Type.
(* using a record/canonical structure *)
Record dtype : Type := { type : Type ; dec : forall a b : type, {a = b} + {a <> b}).
Axiom M : dtype -> Type.
If there is something more complex/restrictive, you could also get away with a deep encoding of the syntax, something like:
(* using a deep embedding of the syntax of types *)
Inductive Only_Nat_Arrow : Type := Nat | Arr (_ _ : Only_Nat_Arrow).
Fixpoint ONAD (a : Only_Nat_Arrow) : Type :=
match a with
| Nat => nat
| Arr a b => ONAD a -> ONAD b
end.
Axiom M : Only_Nat_Arrow -> Type.
Hope this helps.
On Fri, May 15, 2015 at 7:36 AM, Nico <nlehmann AT dcc.uchile.cl> wrote:
Hi all,I want to write a plugin that expose a type that can be introduced only by a ocaml tactic that check if the parameters of the type satisfies a structural constraint regarding the axioms on which it relies.If I hide the implementation of the type using type modules I cannot access the type constructor on the tactic, and thus cannot introduce the type.Is there a way in which I can access a member not exposed in the module type through a ocaml tactic?Thanks
gregory malecha
- [Coq-Club], Nico, 05/15/2015
- Re:[Coq-Club], Gregory Malecha, 05/15/2015
- Re:[Coq-Club], Nico, 05/18/2015
- Re:[Coq-Club], Gregory Malecha, 05/19/2015
- Re:[Coq-Club], Nico, 05/20/2015
