- To: Coq Club <coq-club AT inria.fr>
- Subject: Re:[Coq-Club]
- Date: Mon, 18 May 2015 17:48:31 -0700
Hi, Nico --
Perhaps I misunderstand what you are looking for, but here is an example.
Axiom HiddenType : nat -> Type. (* the natural number should only be 0 *)
Axiom it : forall x, HiddenType n. (* n should only be even *)
Definition using_hidden : HiddenType 0 := @it 0.
Definition bad : HiddenType 1.
let x := eval red in using_hidden in
match x with
| ?X ?Y => exact (X 1)
end.
Defined.
In the example [using_hidden] is meant to be generated via the tactic that you propose. Here, the definition of [bad] avoids using the tactic to construct any a value of type [HiddenType 1]. There is no way in the Coq system to circumvent this.
On Mon, May 18, 2015 at 6:05 AM, Nico <nlehmann AT dcc.uchile.cl> wrote:
On Fri, May 15, 2015 at 3:40 PM Gregory Malecha <gmalecha AT cs.harvard.edu> wrote:Hi, Nico --I don't believe this is possible. If the type is embedded inside of a term, then that term could be opened up via Ltac, and then Ltac could construct a term using constr and avoid your check.I don't clearly understand what do you mean here.It is possible to express your restriction via arguments? For example, if you want a type function that requires a type with a decidable equality there are several ways to do it:I don't think is posible to express the restricion in this way because I need to access the axioms that an argument take as assumptions.
gregory malecha
- [Coq-Club], Nico, 05/15/2015
- Re:[Coq-Club], Gregory Malecha, 05/15/2015
- Re:[Coq-Club], Nico, 05/18/2015
- Re:[Coq-Club], Gregory Malecha, 05/19/2015
- Re:[Coq-Club], Nico, 05/20/2015
