- To: coq-club AT inria.fr
- Subject: [Coq-Club] toy compiler between inductive types
- Date: Fri, 22 May 2015 17:08:51 -0700
Dear Coq experts,
I am looking for some guidance on how to approach in Coq a seemingly simple
problem.
Consider a simple compiler from source to target language, both defined via
inductive types. Target language has stronger typing and not every expression
in source language could be compiled into target. Below is a sample
definition:
Require Import Coq.Arith.EqNat.
Require Import Coq.Bool.Bool.
Require Import Coq.Program.Program.
(* Source language *)
Inductive Source: nat -> nat -> Type :=
| SA (i j:nat): Source i j
| SB (i j:nat): Source i j.
(* Target language *)
Inductive Target : nat -> nat -> Type :=
| TA (i:nat): Target i (i+i)
| TB: Target 0 1.
Now I want to define the compiler function. Something like this:
(* Compiler from source to target. *)
Definition compile {x y i j} (f:nat->nat) (a:Source x y): option (Target i j)
match a with
| SA x y =>
let ni := f(x) in
let nj := f(y) in
if (beq_nat i (j+j)) && (beq_nat ni i) && (beq_nat nj j) then
Some (TA i)
else
None
| SB i j => None
end.
In this example ‘f’ is introduced to demonstrate that mapping between
x,y and i,j is not static.
The compiler returns ‘None' if expression could not be compiled and (Some
Target)
it it could be compiled. For example:
Lemma test1: compile (i:=0) (j:=0) (fun x => x) (SA 2 2) = None.
Lemma test2: compile (fun x => x) (SA 1 2) = Some (TA 1).
My ‘compile’ definition above in incorrect and probably require some tricky
type conversion to make it work. I guess some ‘match’-ing to convince type
checker that i=(j+j). Probably for that I will have to use something like
‘beq_nat_eq’ from standard library.
Assuming I will manage to make it work, a more general question is whenever it
is this the right approach to do things like this? At the end I will have many
constructors for both types and compile function will become quite big and
complex.
Using things like ‘refine’ and/or Program might complicate things even more.
Maybe
there is a pattern how write definitions like this, perhaps splitting it into
several functions? Maybe some of them are easier to proof as lemmas, not write
as functional programs?
Thanks!
Sincerely,
Vadim Zaliva
CMU ECE PhD candidate
Mobile: +1(510)220-1060
Skype: vzaliva
- [Coq-Club] toy compiler between inductive types, Vadim Zaliva, 05/23/2015
- Re: [Coq-Club] toy compiler between inductive types, Gregory Malecha, 05/26/2015
- Re: [Coq-Club] toy compiler between inductive types, Vadim Zaliva, 05/27/2015
- Re: [Coq-Club] toy compiler between inductive types, Gregory Malecha, 05/27/2015
