- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] toy compiler between inductive types
- Date: Tue, 26 May 2015 18:47:49 -0700
> On May 26, 2015, at 18:12 , Vadim Zaliva
> <vzaliva AT cmu.edu>
> wrote:
> Compute compile (i:=0) (j:=0) (fun x => x) (SA 2 2).
> gives me:
> = Some (TA 0) : option (Target 0 0)
> Which is incorrect.
I think the link between formal and computed values of ‘i' and ‘j' was
missing.
I’ve modified you example by adding one ‘if’ statement:
Definition compile {x y i j} (f:nat->nat) (a:Source x y): option (Target i j)
match a with
| SA x y =>
let ni := f(x) in
let nj := f(y) in
if (beq_nat ni i) && (beq_nat nj j) then
cast_nat (Target i) (i+i) j (TA i)
else
None
| SB i j => None
end.
and now it works as expected:
The following:
Compute compile (i:=2) (j:=2) (fun x => x) (SA 2 2).
Compute compile (i:=20) (j:=40) (fun x => x) (SA 2 2).
Compute compile (i:=2) (j:=2) (fun x => x) (SA 1 2).
Compute compile (i:=20) (j:=40) (fun x => x) (SA 1 2).
return ‘None'. And the following:
Compute compile (i:=1) (j:=2) (fun x => x) (SA 1 2).
returns 'Some (TA 1)’
I am still not 100% sure that this is the best way to formalize my problem
but I will experiment with it more. Thanks for your help!
Sincerely,
Vadim Zaliva
CMU ECE PhD candidate
Mobile: +1(510)220-1060
Skype: vzaliva
- [Coq-Club] toy compiler between inductive types, Vadim Zaliva, 05/23/2015
- Re: [Coq-Club] toy compiler between inductive types, Gregory Malecha, 05/26/2015
- Re: [Coq-Club] toy compiler between inductive types, Vadim Zaliva, 05/27/2015
- Re: [Coq-Club] toy compiler between inductive types, Gregory Malecha, 05/27/2015
