coq-club - [Coq-Club] Defining and evaluating a constant in the same vernacular command
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Defining and evaluating a constant in the same vernacular command
  • Date: Thu, 28 May 2015 10:54:35 +0200
Hi,
I've been trying to perform a seemingly trivial feet but I am not getting anywhere with it. My eventual goal is to define multiple constants, some of which contain proofs which I can only construct by evaluating previously defined constants. This is supposed to happen in one vernacular command.
In my current setup I am trying to mirror what happens in the Definition vernacular, i.e. calling Command.declare_definition. Once the vernacular command is fully interpreted the definition is ready to be used, evaluated, etc. So far so good. However, within the command (after calling declare_definition) I seem to be unable to delta-reduce the constant. My attempts fail with "Uncaught Exception Not_found" in hMap.ml.
Now, seeing how the constant is eventually declared correctly at the end of the command, I wonder what it is I need to do within the command to achieve the same effect earlier.
Any help is much appreciated!
Cheers
Jan-Oliver
  • [Coq-Club] Defining and evaluating a constant in the same vernacular command, Jan-Oliver Kaiser, 05/28/2015
