- From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] Type Classes and Module Types
- Date: Thu, 28 May 2015 12:06:40 +0000
- Accept-language: de-DE, en-US
Dear Lawrence,
I am still a beginner with Coq, but may be my observations help a bit. First
I would say there are 3 mechanisms:
- records containing proof terms like classes but not using automatic
instance resolution
- classes and instances with automatic instance resolution
- the module and module type system
The first two have the advantage that the records and classes are Gallina
terms, which can be passed and returned to/from functions, stored in records
and so on. You can pass a module only to a module function, but not to a
Gallina function, which computes something. The latter gives a lot of
flexibility, which is not easily possible with Modules.
In complicated cases I sometimes prefer simple records over classes. The
automatic instance resolution is very handy, but if things get complicated, I
found that it can be more work to find out why the instance resolution
doesn't do what you want than doing the instance resolution manually.
The main advantages of modules I see is that they have a lot syntactic sugar
and comfort features to combine and organize modules.
So I see modules mostly as an elegant way to organize and to abstract
libraries. For building up complex nested structures, classes or records are
more useful.
Best regards,
Michael
-----Original Message-----
[mailto:bytbox AT gmail.com]
On Behalf Of Scott Lawrence
Sent: Wednesday, May 27, 2015 9:50 PM
To:
Subject: [Coq-Club] Type Classes and Module Types
Hi all,
Many of the same things can be done via `Module Type` and `Module` as with
`Class` and `Instance`. Are there any good rules of thumb for when to use
which? For example, either could be used to define VectorSpace <
NormedVectorSpace < BanachSpace -- is there a reason to pick one over the
other?
(Somewhat pettily, I find the syntax resulting from using the module system
to be far cleaner. I also note that the documentation declares type classes
to be very experimental.)
Thanks,
Scott Lawrence
- [Coq-Club] Type Classes and Module Types, Scott Lawrence, 05/27/2015
- RE: [Coq-Club] Type Classes and Module Types, Soegtrop, Michael, 05/28/2015
- Re: [Coq-Club] Type Classes and Module Types, Cedric Auger, 05/28/2015
- Re: [Coq-Club] Type Classes and Module Types, Scott Lawrence, 05/28/2015
