coq-club - RE: [Coq-Club] "simpl" control
  • From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: RE: [Coq-Club] "simpl" control
  • Date: Fri, 29 May 2015 12:38:55 +0000
  • Accept-language: de-DE, en-US
Dear Ralf,
Coq 8.5 has a new replacement for simpl, called cbn. The manual says "The cbn
tactic is claimed to be a more principled, faster and more predictable
replacement for simpl". The cbn tactic can be fine tuned using the Arguments
command and with a few options. I made good experiences with cbn. I think it
would solve your problem as well.
Best regards,
Michael
-----Original Message-----
coq-club-request AT inria.fr
[mailto:coq-club-request AT inria.fr]
On Behalf Of Ralf Jung
Sent: Friday, May 29, 2015 1:47 PM
To:
Subject: [Coq-Club] "simpl" control
Hi all,
I am currently struggling a lot with the simplification of Coq often going
way too far, and unfolding terms so deep that the result is huge, and
unusable.
In particular, to control simplification of "equiv" (the general extensional
equality, type: forall T, Setoid T -> T -> T -> Prop) I now have the
following "Arguments":
Arguments equiv {_ _} !_ !_ /.
Lots of times, that does what I want: When I have an equality of two
(explicitly written down) pairs, that reduces to the conjunct of the two
inner equalities. Same for option types. However, unfortunately, the check
for constructors being in argument position is "too clever": It reduces even
if there is a function call that results in ultimately a constructor being in
head position. For example, if I have
Definition unit t := (foo, t).
Goal: unit somet == (fooz, barz). simpl
(* "==" is infix for "equiv" *)
then this will simplify. But I don't want that to happen! This often goes way
too far, and I'd rather explicitly "unfold unit; simpl" in the few cases that
I actually want a reduction to happen. Currently, I am using ssreflect's
"locked" mechanism to work around that in a few places. But that's not always
possible, sometimes I really need the terms to remain convertible, or else
things will be really painful.
So, in decreasing order of preference, I wonder whether any of the following
is possible:
* Can I do something with unit that's a bit like "locked" in that
it prevents Coq from recognizing constructors "through" unit,
but retains convertibility? I tried
Arguments unit t : simpl never.
But that does not stop Coq from simplifying unit in this case.
Is there a "simpl never and I mean it"? I also tried "nosimpl"
from ssreflect, to no avail.
* If the above is not possible, is there something I can do to the
"Arguments" of equiv such that it only reduces if a constructor
is present *syntactically* in argument position, *not* considering
delta reduction?
* And as a last stop, is there some way to make the reduction on equiv
dependent on the first argument? Say, generally I do not want equiv
to reduce, but if the first argument is a "T * S" or an "option T",
I want it to reduce if there is a constructor in both argument
positions. (That wouldn't help above, but most of the cases where
annoying simplification happens are with new types I define myself,
where I am okay with things never simplifying. Plus, this may help
with some other trouble I am having, which I did not understand well
enough yet to even ask specific questions.)
So far, I tried Coq 8.4 only. Have there been noticeable changes to
simplification in Coq 8.5?
Any help would be appreciated.
Kind regards,
Ralf
