- From: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] "simpl" control
- Date: Fri, 29 May 2015 14:43:34 +0200
> Le 29 mai 2015 à 13:47, Ralf Jung
> <jung AT mpi-sws.org>
> a écrit :
> So far, I tried Coq 8.4 only. Have there been noticeable changes to
> simplification in Coq 8.5?
Coq 8.5 comes with a tactic called cbn that is barely a backward compatible
in place remplacement for simpl (There is even an option SimplIsCbn so that
any invocation of simpl calls the cbn machinery. It is not perfect and
therefore not done by default: activating it on the standard library requires
to modify 50 lines for example.)
It use the same syntax as lazy or cbn to allow the control constant by
constant of which one can be unfolded while doing the « simpl » refolding
stuff.
For example, ''cbn -[unit]'' means (more or less) apply simpl but do not
unfold the constant unit where ''cbn [mult plus]'' means apply simpl but
unfold only mult and plus, etc
Pierre B.
- [Coq-Club] "simpl" control, Ralf Jung, 05/29/2015
- RE: [Coq-Club] "simpl" control, Soegtrop, Michael, 05/29/2015
- Re: [Coq-Club] "simpl" control, Pierre Boutillier, 05/29/2015
