coq-club - Re: [Coq-Club] opam dev version
  • From: Philipp Haselwarter <philipp+coq AT haselwarter.org>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] opam dev version
  • Date: Fri, 12 Jun 2015 09:40:44 +0200
  • Microsoft: With our software, there's no limit to what you can't do!
Using coq:shell with the dev profile, you'll add the coq-core-dev repo
to opam. So
opam install coq:shell
opam update
opam pin add coq dev
should make you #trace trunk I think, but might pull in too many dev
packages for you taste. The lightweight solution is
`opam pin add coq git://github.com/coq/coq#trunk`
Philipp Haselwarter
