coq-club - Re: [Coq-Club] CoqIDE loadpath error for ssreflect
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] CoqIDE loadpath error for ssreflect
  • Date: Fri, 12 Jun 2015 10:40:31 +0100
Hi Ralf,
I used the following instructions in CoqIDE:
Add LoadPath "/opt/local/lib/coq/user-contrib/Ssreflect/".
Require Import Ssreflect.ssreflect.
but got the error: Cannot find library Ssreflect.ssreflect in loadpath
Also, the file ssreflect.vo is in the folder.
Kind regards,
David
On Thu, Jun 11, 2015 at 7:48 PM, Ralf Jung <jung AT mpi-sws.org> wrote:
Hi,
> Thanks for the suggestion.
> Unfortunately when I followed the instruction I got the following
> error: Cannot find library ssreflect in loadpath
> What file extension should the ssreflect library have ( I would like to
> check that it is in the folder ) ?
Please try "Require Import Ssreflect.ssreflect".
There should be a file
/opt/local/lib/coq/user-contrib/Ssreflect/ssreflect.vo.
Kind regards,
Ralf
