coq-club - Re: [Coq-Club] admit, Qed, and Print Assumptions
  • From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] admit, Qed, and Print Assumptions
  • Date: Fri, 19 Jun 2015 10:43:21 +0200
On 18/06/2015 18:43, Christian Doczkal wrote:
Hello
I was just looking at the Changelog for Coq 8.5beta2 and I noticed the
following:
- A script using the admit tactic can no longer be concluded by either
Qed or Defined. In the first case, Admitted can be used instead. In
the second case, a subproof should be used.
Is this a temporary measure, or is there a principled reason why this cannot
work in Coq 8.5?
Basically, admit no longer generates a fresh axiom, but instead it simply discards the current goal. As a consequence, the final proof term still contains holes (and thus is ill-formed), so Qed cannot be used to save it.
I someties use this in combination with Print Assumptions to get a quick overview of
all the "holes" in some theorem.
I don't know what is the best way to achieve this, but anything that displays the holes of your proof will work. For instance, you could type "Show Existentials" just before "Admitted".
In fact, Coq somehow does that for you: "No more, however there are goals you gave up. You need to go back and solve them: ...". Hmm... I now notice that the message syntax is a bit approximative. I should fix that.
Best regards,
Guillaume
