coq-club - Re: [Coq-Club] program_simpl and automatic discharging of Program Fixpoint conditions
  • From: Clément Pit--Claudel <clement.pit AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] program_simpl and automatic discharging of Program Fixpoint conditions
  • Date: Tue, 23 Jun 2015 09:17:47 -0700
On 06/22/2015 11:25 AM, Tej Chajed wrote:
> When you do [Next Obligation], [program_simpl] is automatically
> applied before you enter proof-editing mode. The obligation in your
> example can't be solved with [program_simpl], but two applications
> does solve it, so [Solve Obligations with (program_simpl;
> program_simpl)] will work.
Correct, thanks Tej!
> -Tej
> On Mon, Jun 22, 2015 at 2:15 PM Clément Pit--Claudel
> <mailto:clement.pit AT gmail.com>>
> wrote:
> Hi list,
> In both 8.4 and trunk, the following program leaves one obligation:
> Require Import List Program.
> Program Fixpoint zip
> {A B : Set} (a : list A) (b : list B)
> (p: length a = length b) : { l: list (A * B) | (length l =
> length a) } :=
> match a, b with
> | x :: y, x' :: y' => (x, x') :: (zip y y' _)
> | x :: y, [] => !
> | [], x :: y => !
> end.
> [Solve Obligations using program_simpl] doesn't solve that remaining
> obligation, but the following does:
> Next Obligation.
> program_simpl.
> Defined.
> Is there something fishy going on here, or am I making an incorrect
> assumption?
> Clément.
