Re: [Coq-Club] program_simpl and automatic discharging of Program Fixpoint conditions
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] program_simpl and automatic discharging of Program Fixpoint conditions
- Date: Mon, 22 Jun 2015 18:25:45 +0000
When you do [Next Obligation], [program_simpl] is automatically applied before you enter proof-editing mode. The obligation in your example can't be solved with [program_simpl], but two applications does solve it, so [Solve Obligations with (program_simpl; program_simpl)] will work.
-Tej
On Mon, Jun 22, 2015 at 2:15 PM Clément Pit--Claudel <clement.pit AT gmail.com> wrote:
Hi list,
In both 8.4 and trunk, the following program leaves one obligation:
Require Import List Program.
Program Fixpoint zip
{A B : Set} (a : list A) (b : list B)
(p: length a = length b) : { l: list (A * B) | (length l = length a) } :=
match a, b with
| x :: y, x' :: y' => (x, x') :: (zip y y' _)
| x :: y, [] => !
| [], x :: y => !
end.
[Solve Obligations using program_simpl] doesn't solve that remaining obligation, but the following does:
Next Obligation.
program_simpl.
Defined.
Is there something fishy going on here, or am I making an incorrect assumption?
Clément.
- [Coq-Club] program_simpl and automatic discharging of Program Fixpoint conditions, Clément Pit--Claudel, 06/22/2015
- Re: [Coq-Club] program_simpl and automatic discharging of Program Fixpoint conditions, Tej Chajed, 06/22/2015
- Re: [Coq-Club] program_simpl and automatic discharging of Program Fixpoint conditions, Clément Pit--Claudel, 06/23/2015
