- From: Kenneth Adam Miller <kennethadammiller AT gmail.com>
- To: coq-club Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Tip&trick: getting a Coq-able OCaml toplevel from Emacs
- Date: Wed, 24 Jun 2015 11:16:25 -0400
I personally like isend-mode for allowing any subprocess to be associable with a buffer. You can then iteratively send your script fragments to the toplevel, and work out all changes in a buffer that you can then save! It's like SLIME, if you've ever heard or seen that.
On Wed, Jun 24, 2015 at 10:59 AM, Gabriel Scherer <gabriel.scherer AT gmail.com> wrote:
Hi coq-club,
During the Coq Coding Sprint, Thomas Sibut-Pinote asked for a way to
start an ocaml toplevel (from the Emacs buffer showing OCaml code of a
Coq plugin) that would already know about Coq library and internal
modules.
You probably already know that you can get an OCaml-able toplevel from
coqtop using the "Drop." command,
$ coqtop.byte
Welcome to Coq 8.4pl5 (November 2014)
Coq < Drop.
OCaml version 4.02.2
Camlp5 parsing version 6.13
# #use "include";;
The point of this mail is to let know this from Emacs (using caml-mode
or tuareg-mode):
- use whatever command your emacs-ocaml-mode uses to launch a toplevel
(Tuareg: C-x C-e)
- ask for "coqtop.byte" as a toplevel name
- run the command "Drop. Drop. ;;"
- then #use "include";; as usual
(Yes, you need two commands instead of just Drop., and you need the
two semicolons; this is the trick, found by Jacques-Henri Jourdan.)
- [Coq-Club] Tip&trick: getting a Coq-able OCaml toplevel from Emacs, Gabriel Scherer, 06/24/2015
- Re: [Coq-Club] Tip&trick: getting a Coq-able OCaml toplevel from Emacs, Kenneth Adam Miller, 06/24/2015
